Question about Linksys Wireless-G WRT54G Router
Lost security key cant connect, box pops up wanting key need to change or get new onenot sure how.
    Sergeant:
  • 260 Answers
Press the reset button for 30 seconds. This will restore the default settings. The Linksys default user name and password are both "admin" without the quotes. You will have to reconfigure the security settings.
Posted on Mar 12, 2009
How do i find a key for my linksys router?
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You should be able to see your present wireless network security key on this screen. You can also use this screen to change the key if you want.
If you want to make some changes first select the security mode you want to use.
I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless devices. After the first time they connect to the secured network they should automatically remember the security code. I hope this advice helps you out.
Nov 26, 2011 | Linksys Computers & Internet
How do i find my network key for my router lynksys wirelass wrt54gs
Nov 03, 2011 | Linksys Wireless-G WRT54GS Router...
Cant change my security key of my router
Try this one Instructions
1. Power on any of the computers that are currently connected to a network through your Belkin wireless router. Click on the "Start" button and then open the Control Panel.
2. double-click the "Devices" icon. Right-click on the entry for your Belkin wireless router and click on "Update Driver." Wait for the latest software driver to finish downloading and then close the Devices window.
  1. Open your web browser by clicking on its corresponding desktop icon. Click on the address bar at the top of the web browser's window and type in the string of numbers and dots "192.168.2.1" Press the Enter key to bring up the router's access page. Click on the "Login" button.
4. Leave the password text box blank and then click on the "Submit" button to access the settings menu. Click on the tab at the top of the screen labeled as "Wireless."
5. Find the "Security" link at the center of the page and click on it. Click on the "Security Mode" drop-down menu box and then change the security mode to whichever setting you want. Choose the "128 bit WEP" option from the drop-down menu if you want to enable security encryption on your wireless network.
6. Click on the "Generate" button at the bottom of the screen to generate the encryption key and then type in a password you want to use in the "Passphrase" text box. Leave the box empty if you want anyone within range to be able to access your wireless router. Click on the "Apply Changes" button to save the changes. source "ehow"
Jul 02, 2011 | Belkin Basic Wireless Router
Lost paperwork to my berklin wireless router, need to know how to put a security password to log on. i live in an complex and there are some people i believe are hacking in. my computer is new and running...
Hi here is the answer if you want to setup wpa/wpa2 security then follow the below seps
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Sep 26, 2010 | Computers & Internet
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
Cant figureout how to set a password to a d-link router
Hi…I’ll try and lend a hand. There are several ways to set up wireless security on this router. However, I’ll help you set it up using the manual method.
Important note: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
I’m sure you have done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
Select ‘Admin’ from the dropdown box, then enter your password IF you have set one – otherwise, just leave the field blank and press return.
You should then see the configuration screen/user interface.
2) Change the router password.
If you HAVEN’T set a password, this is a good place to start. Go to Tools >Admin option. Set and confirm a password for ‘Admin’, and note it down. Also, set and confirm a password for ‘User’. Click ‘save settings’ when finished.
Make sure these passwords are not easy to guess, or a neighbour could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Setup > Wireless Settings. You should see an option marked ‘Wireless Network Name’ or SSID. Change this from the default, ‘dlink’, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘save settings’ when finished.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Wireless Security Mode’ section. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
You should see a dropdown box marked WPA Mode – select Auto. Leave Group Key Update Interval at the default of 3600s.
Under Pre-Shared Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Dec 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
Passwords
If you don't know the WEP key, then the security is working (ironic, isn't it?)
If you want the Wii online, you will need to log into the router's interface and disable encryption entirely or (depending on the router) simply change the security key.
Bear in mind that if you change the key, all the other wireless devices will no longer work until you update them with the proper key.
Hope this helps - be sure to rate :)
Sep 08, 2008 | Belkin (F5D7231UK4) Wireless Router
Encryption
To secure your belkin wireless network you need to type http://192.168.2.1 into your internet explorer or click on the link in this message.
On the left menu click on security,
Down the box choose 64 bit WEP OR 128 bit WEP.
Select Automatically generate hex pairs using Pass Phrass by placing a tick.
Type in a Pass Phrass in the box and click Apply Changes.
It will open a new window with encription key.
Write it down and keep it a good place.
Close your browser and you are done.
Click on your network icon to search for wireless, when found your network SSID, double click to connect and a pop up window will ask for the encription key.
Type in the key and confirm it and that's all the game.
Hope that help.
Jun 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
