Question about Nokia Cell Phones
My nokia c3-01 is having blinking white screen then goes blank
White screen blinking and blank
  • 3 Answers
SOURCE: My E61i screen suddenly goes blinking and blank
Let me guess ... you dropped the phone at least once recently?
Well, I did the same, and the first three times I got it working by smaking it face-up on the table (literally!). However, this morning was the last straw, and I could not get it working again.
However, I now know this is an easily repaired problem that someone with very basic skills and tools can tackle. With the earlier crude remedy I suspected a loose contact, and this was confirmed by squeezing the phone just right between the power light and the speaker I got the backlighting to work. To fix it, the steps are:
- Remove battery cover
- Remove battery
- Start disassembly by removing top rear shell (the bit with the lens cover) by gently prising with a small screw driver. There are five catches - one middle left, one middle right right, one center bottom, two at the top +/- 1/2" from the edges. Gently remove the in the same direction as you would the battery.
- Remove front shell by undoing 4 screws now visible on the rear of the phone, one at each corner. Itis a funny torque screw, but I used a small flat and it worked OK
- Turn the phone face up. Right at the top and about 1" from the left there is a red screen connector (you'll see the copper of the screen's strip cable terminating there). Gently press down on this connector to reconnect, and Hey Presto!
- While you're about it, remove all the dust and muck in the phone.
- Reverse the steps for re-assembly
If you do not feel up to it, take the phone to an agent or repair shop with these instructions. It is a 5 minute job and they should charge accordingly!
Francois
Posted on Nov 12, 2008
Techy101
  • 132 Answers
SOURCE: after power on screen show nokia logo then blank off
Your device is experiencing software issues. You try by removing the battery for 30 seconds and then replacing it. This is soft reset. If the device still fails to load software, then you should visit your local repair shop for a replacement.
Posted on Mar 13, 2009
  • 77 Answers
SOURCE: my nokia 3110c is not switching on
Check if battery on the phone depletes fast. If there's nothing wrong with the battery try poercycling the phone (turning phone off and removing battery from the back and insert battery after 1-2 mins). If the problem persist try master resetting the phone. Remember that by doing the master reset it will delete some of your saved info on the phone.
Posted on Sep 05, 2009
AldRezaine
  • 995 Answers
SOURCE: nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Posted on Mar 26, 2010
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
caroldon
  • 17130 Answers
SOURCE: my nokia x3 wont start
Remove the battery and the SD memory card, check the card for corrupt/virus infected files that have corrupted the software. Now have it scanned on your PC and remove/format the card.
Reset to the phone and check , if the fault comes back then the software must be installed on the phone. have this done at the Nokia care/support center.
Posted on Jan 17, 2011
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
Nokia 5130: blank screen, phone doesn't turn on
Mar 26, 2010 | Nokia 5130 Cellular Phone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
Screen blanks out while am using,
ur screen is been misplaced . open it and plug it correctly thats it
May 07, 2009 | Nokia N72 Cellular Phone
After power on screen show nokia logo then blank off
Mar 13, 2009 | Nokia 5310 Cellular Phone
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
Cell Phones Logo
225 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
