WFMC3200UC stops half way through the cycle and wont finish
Have a Bosch front loader, lately when running laundry the washer will start to fill with water and acts like everything is fine with the load. About 45 minutes later when going to change the load, it has stopped and shows time still left on the machine. Some times the fabric softner is still there so you know that the load was never washed. There is now also an oder (like sewage) that is coming from the washer. It's a hit and mix when the washer will work. When this does happen, the light shows that the door is locked but you can open the door. Normally have to change the cycle to spin just to stop the clothes from being drinched. Does any one know what is wrong and what we can do to fix it? We have cleaned the trap multiple times and even bought the tablets to put in the washer to clean it but nothing seems to be working. HELP!!!!
  • 27 Answers
Sounds and smells like a heating problem if the appliance is not heating it will not complete the cycle and as the detergent starts to break down it makes the appliance smell
Posted on Mar 13, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Can't get retaining rings back on boot gasket on Bosch 3200uc
You can google for them or look on this site Fixya for spares.
Mar 19, 2013 | Bosch WFMC 3200 Front Load Washer
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
I HAVE A BOSCH FRONT LOAD WASH MACHINE MODEL WFMC3200UC. IT WILL FILL AND THE LIGHT COME ON TO WASH AND THEN IT STARTS PUMPING OUT THE WATER.
B This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 02, 2011 | Bosch WFMC 3200 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Jul 25, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Mar 15, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
WFMC3200UC Broken Plastic Piece
here is a link which shows the exploded diagram for your washer - perhaps you can identify the part; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM and here is the parts list; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM at the top you can order parts direct from bosch. Here is the link to the user manual if you need it; http://www.bshextranet.com/files/techtoolbox/WFMC3200uc.pdf If you have no luck with this then; Best thing you can do is to take a picture of the part and where you think it came from, and either post it again here or e-mail it to your nearest bosch dealer (page 26 of the manual has a phone number). Hope this helps :) ps - if you do contact them, please tell Bosch how good the access to their product literature is - if all manufacturers did this our landfill sites would be half as full - they deserve some praise :)
Mar 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
