Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Unplayable disc
By g rubz on Aug 05, 2007
so i use to lay my xbox360 flat until one day for no aparent reason i stood it up. soi played for about an hour or 2then shut it off. when i came back i turned my xbox on and it went to the dashboard and where it should have said the name of the game in the disc trayit read unplayable disc and none of my games work please help im haveing withdrawls
Clarification Request
Posted by sdaku on May 05, 2009
Solution Link . . . www.MicrosoftXbox360Console.com
Same Problem
Apr 28, 2009
-   my xbox starts but as soon as the game gets going it frezzes up plays dvds just fine but there are spec dance around the scrren-   Guest
Jan 16, 2009
-   it has a ring around the disc-   Guest
Dec 03, 2008
-   Well i was playing Halo 3 and i got tired and went to bed and when i tried to play it the next morning on the dash board it kept saying unplayable disc. What should i do?-   Gunslinger13
Aug 08, 2008
-   i  put in a  x-box 360 game into my x-box 360 console and it went to the dashboard where it should say the game it said unplayable disc, but my disc worked perfectly fine on my friend x-box 360 console.-   okmssoccer9
Jul 25, 2008
-   it telling me unplayable disc -   dagwood8667
Best Solution
posted on Aug 07, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Magnetic washer holding the disk in place wore of due to heat. http://www.youtube.com/watch?v=MvgU1lC8k8k
Solution #2
posted on Oct 03, 2007
Very Helpful)
Roblamont80
Rank: Master
Rating: 87%, 17 votes
3 year warrenty only covers the red ring of dealth.
Was this helpful?
Yes
No
Solution #3
posted on Aug 23, 2007
Helpful)
PrimoDread
Rank: Guide
Rating: 88%, 21 votes
The other suggestion is overtly wrong - you have a fatal error that needs to fixed by xbox repair center in McAllen,TX. This should now be covered by the new 3 year extended warranty. This problem is one of two major flaws with the xbox 360. The first is the heat problem which is the underlying cause of the three rings of death(now covered). the next is your problem which is a hardware failure of the disc drive. Rumor is that xbox live update actually crashed alot of drives by mistake trying to ban modders from xbox live via the update. So either cheap drives to begin with or funky firmware, your guess is as good as mine. Call xbox support - get the ball rolling cause it takes about a month for them to ship you a refurbished xbox with all the same problems - alot of horror stories out there about people getting 3 or 4 xbox 360 deaths......
Was this helpful?
Yes
No
Solution #4
posted on Aug 05, 2007
Somewhat Helpful)
Rocket976
Rank: Master
Rating: 78%, 49 votes
Your system is fine, the disk is a different story. By moving your Xbox 360 the drive does some funky things. The disk probably has some deep grooves around the egde. In future, dont move the 360 or backup your xbox 360 games with http://www.everything4360.com
Support
Rich
Was this helpful?
Yes
No
Solution #5
posted on Jul 19, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
FixYa experts found the solution. Check here
Solution #6
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
okay we had the same problem...
we always laid it on its side and one day we switched rooms it was in and we could stand it and we did... then the screen was hard to read so we switched back to the other room laying it down agian and then it stopped reading the disks... but all we had to do was find a way to sit it up leave it off for 2 days so it could cool down got it near a vent so it stays cooler and now it works... occasionally we have to restart the system when it doesnt work but only once or twice never more... i hope that can work for you guys too...
Solution #7
posted on Jul 04, 2008
Not Rated)
pittbull_eq
Rank: Apprentice
Rating: 0%, 0 votes
Ok here it is The first time it did it to me it took almost 10 to 12 times of turning off and takin out to finally get it to read it. Now somtimes it only takes like 2 maybe 10 last 3 times i played it took 2 times. Ok sounds are loud reading and I think i can hear laser :(.
Was this helpful?
Yes
No
Solution #8
posted on Feb 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same here disc's are find but still report disc as unplayable.
I call MS and they said this is a known issue but not covered by the new warranty.
It looks like it an issue with the dvd player. The
Solution #9
posted on Jan 01, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Okay so here is the thing with mine. I bought Timeshift and put it in my X-box 360 and it said unplayable disc. So i took the disk back because i have no problems with any of my other games. I put the new timeshift into my console and it still didn't work. Then i put it in my brothers 360 and it works. so its not the disc. i have no idea what the problem is
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
cant sign in to xbox live because when i try it says enter pass code
Answer
All of a sudden our xbox 360 isn't saving anything to memory. The memory to our xbox is completely... (More)
Answer
transfer the key switch on a new cd drive...x box 360
20 Other Users Have The Same Problem - Continued
Comment by cod4champ, posted on Jul 07, 2008
in the afternoon my 360 was working fine i left for about 5 hours came home to play cod4 and it read unplayable disc i tried every game after that and none of them would play i tried wrapping my 360 in a towel that didnt work so now all i can do is try demos
Comment by Guest, posted on Jun 24, 2008
,';KL'"::'":
Comment by shaychick25, posted on Jun 19, 2008
Ours is doing the same. every disk we put in it reads as UNPLAYABLE. sooo...has anyone figured out why they are doing this?????
Comment by FredyGibb, posted on Feb 28, 2008
All of a sudden got unplayable disc error when trying to play game or audio cd in xbox 360.
Contacted xbox toll free number and was told it would cost 110 dollars US to fix.
Comment by emeryross, posted on Feb 27, 2008
Same really, the drive is also louder than normal kinda like a grinding sound. Some times the games play, sometimes they dont.
Comment by Guest, posted on Feb 11, 2008
325654654+654+6546546544654654
Comment by ivoryline13, posted on Jan 16, 2008
Same problem
I took my 360 to a local video game store and they replaced my DVD drive for $128
I come home excited to play after waiting 2 weeks, and it does the exact same thing as before
I then furiously punched a hole in my wall.
Comment by sheldo, posted on Jan 05, 2008
screen reads unplayable disc on all games and dvd's hope you have an answer to fix problem.
Comment by Bigman 42, posted on Dec 26, 2007
I'm tryin to play Need for Speed ProStreet and College Hoops 2K8 and both discs showed up as unplayable. There is no damage to the discs
Comment by Guest, posted on Dec 19, 2007
I was playing my xbox all day one day. then the next day i turned it on and ever game dvd or cd i put in reads as unplayable. all i can play are demos from xbox live or arcade games.
Comment by robdaman, posted on Dec 03, 2007
yeah, i have the same problem every game,movie and cd says that and like the other "post" i can play demos too
rob
Comment by Guest, posted on Nov 24, 2007
my games are reading as unplayable disk
Comment by rea rea, posted on Nov 24, 2007
unplayable disc continues to show up on my dashboard even when i put in a brand new game it started after having a regular cd in it then when i changed it out with another game it started to show me this please help
Comment by Guest, posted on Nov 19, 2007
My xbox 360 says unplayable disc when ever i put any games on it in the xbox menu,what is there to do about this??
Comment by Guest, posted on Nov 11, 2007
I tried to play Halo 3, Timeshift, and other games, but it always reads them as unplayable. The inly games i can play on my 360 are game demos.
Describe your Video Game Consoles problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
