Rank: Wiz
Rating: 85%, 32 votes
Hello my name is Tim Ehrhart and I hope this helps
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section belowE45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Please leave feedback as I am new and wanne gain a good rep. Thnk You
