Question about Ovens
DIPLOMAT OVEN ADR 3300
Can't get timer to work and auto symbol is flashing
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 18, 2010
blackmar
  • 235 Answers
SOURCE: i have a diplomat double
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Posted on Feb 05, 2011
SOURCE: cant get oven to work after power cut,creda gainsborough 48185
Hold down minute minder + cook period buttons. The + or - buttons will then set time.
Posted on Aug 28, 2011
Numbers rubbed off Diplomat ADP3640 oven
Have the same diplomat the numbers have come off to . I have mine on twenty to if you was looking at a clock and it's about 180 . Half past is 160 . Right to top 220 .
Feb 16, 2013 | Ovens
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Feb 05, 2011 | Ovens
Need a user manual for a Hygena diplomat oven model AHY 3420 any ideas please?
I have a manual for AHY3420, it's a very generic manual which covers different ovens. I am happy to send you a scanned copy if you send me an e-mail address.
I have the same oven and all the symbols have disappeared on the third dial (the one which switches on the oven), so I still haven't worked out which setting does what - I can just about make out a grill symbol, but that's about it. Is there any chance you could tell me what the symbols are on the 3rd dial?
Thanks very much.
Sigrun
Feb 10, 2010 | Ovens
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ovens
Neff B1428
If it is a digital timer and u have display, thenyou must make sure it is set to manual and not flashing auto, or the oven will not work.
If it is an anologue timer tweak the knobs until you can see a hand symbol showing this is the manual mode.
If no display of any kind, and u are sure u have a supply to oven then timer could be faulty.
Hope this helps.
U must ensure that u have a supply to the oven befor trying to alter timer.
Plz rate solution.
Thanks.
Dec 31, 2008 | Neff B1428 Nostalgic Single circotherm...
Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Aug 27, 2008 | Ovens
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
