Question about Sansui VRDVD5000 DVD Recorder/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Have lost user manual - tried pressing menu then ok nothing happens also pressed setup only takes me to some setups not clock
  • Sansui Master
  • 520 Answers
Go into SYSTEM SETUP. thats where the clock settings are.
Posted on Mar 14, 2009
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Set clock on sansui vhs dvd player
You must first be sure your remote is set to VCR by pressing the VCR/DVD button.
Then press SETUP/VCR MENU button.
Use your arrow buttons to select SYSTEM SETUP.
On the next screen select CLOCK SET,
Press enter until you get to the time selection.
Use your right arrow to increase or left arrow to decrease the hour or minutes, Then press ENTER.
Press VCR/DVD if you wish to return the DVD display.
Aug 02, 2009 | Televison & Video
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
Finalizing a disc
If you have the user's guide, It's on page 37 in the Owner's Manual.
--Press 'SETUP'
--Scroll to select 'DISK EDIT'
--Press 'OK'
--Scroll to select 'FINALIZE'
--Press 'OK'
--Scroll to select 'YES'
--Press 'OK'
--Finalizing begins!
Jun 27, 2008 | Philips Magnavox DVD/VCR Dual Player
Setting clock on older VRDVD4001AC
According to the manual, to set the standard time, you should press VCR MENU, then SET + OR - to select System Setup. Press ENTER. Press SET+ OR - again and then choose STANDARD TIME followed by ENTER to set your own time zone. Press SET + OR - one more time to select your time zone, and then again press ENTER. To return, press VCR MENU twice.
Just a note: The unit is set to AUTO CLOCK when it is shipped. If you leave it this way, the clock will set itself after you plug in the unit provided you do not press POWER for at least three minutes when you first plug it in. Also, your cable box or antenna must be attached in order for it to find the time.
Mar 12, 2008 | Sansui VRDVD4001 DVD Player/VCR
DVD Recording from Television on DVD and VHS
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
Dec 18, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD5000 DVD Recorder/VCR Logo
364 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
