Question about Refrigerators
How to repair itv ice machine the water not colling no produce ice and the condensing fan motor sometimes it stop
2 Suggested Answers
  • 54 Answers
SOURCE: Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Posted on Jul 03, 2008
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Ice maker stopped working
I would first check around the condensing area for lint and dust buildup and clean that up. Just doing so can sometimes get the ice maker cold enough to start producing ice. Their are 2 components that are responsible for ice production. The ice maker and the water valve. As the ice maker dumps a batch of ice near the end of that harvest cycle the ice maker powers up the water valve for 7and a half seconds. How. A probe rubs on a copper plate mounted on the inside of the main gear. Here is how she works: The ice mold thermostat gets down to around 28f. This makes it close contacts and power up the mold heater and the motor. As the ice loosens up and moves a bit you hear a click. That click kills power to the ice mold heater. The motor continues on around to dump the ice. After the ice goes home to bucketsville the copper plate rubs against the water solenoid probe and water is sent up the backsides of the icebox to the ice mold for 7.5 seconds. If you are careful you can remove that wheel and clean that plate. A simple test and a manual HERE
Aug 18, 2010 | Whirlpool Refrigerators
Heated panel
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
May 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Very hot frame
May 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making ice, making a loud humming noise its a top freezer RT18BMXBL01
The ice maker has completely stopped producing ice:--Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly :--When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Noise can come from these areas:
The inside of the freezer :--Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator:--There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator:--Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
This will help.thanks.
Feb 21, 2010 | Roper Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
