Grundig glx 3001 C pin code reset
Hi Im a chief engineer on a tugboat and when i came onboard i couldent search chanells on my Grundig 32 GLX 3001 C television and noticed that the Child lock were on, I dont have the pin code and tryed (0000,0123,1234) is there a way to reset the pin code? Best regards Tobias
  • 298 Answers
SOURCE: loewe tv problem
Links to manuals code information will be in manual
http://www.loewe.user-manuals.com/loewe-c-88.html?page=2&sort=2a
http://www.schematic.com.ua/english/I_TV_e/l.shtml
Posted on Jan 01, 2008
SOURCE: child lock
my daugter lock my sharp aquos with the child lock and i don,t know the pin
Posted on Oct 23, 2008
  • 13 Answers
SOURCE: Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Posted on Mar 18, 2009
SOURCE: harwa tv childlock code
Harwa password is 000000
Posted on Apr 07, 2009
SOURCE: Child Lock on Insignia TV
I CAN HELP! After my having my Insignia NS-20LCD picture locked for over a year because no one could give me a way to unlock it, a co-worker found the secret!!
When facing the back of the TV, there is another on/off switch on the back on the right side just under the curve (very difficult to see). I didn't even know it was there.
Once you locate, turn the set on using that switch while you hold in the "menu" button on the right side (when facing the front) of the TV. This will reset the television and unlock the screen!
Real Woman of Genius ... Janice Petroff!
Posted on Jul 07, 2009
My TVS Victor GLX 125 is missing at slow speeds also the VTI indication light is blinking. Why?
Hi, Arun and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
TVS Victo GLX 125 Long Term Ownership Team BHP
TVS Victor GLX 125 2007
http://www.tvsmotor.com/pdf/Manuals-Scooty-Zest-110.pdf
Shop at TVS Victor glx Parts And Accessories Online Store safexbikes com
http://fullmanuals24.com/brand/tvs
Sep 18, 2016 | Motorcycles
My 2001 glx beetle is idling high when i start it after it is up to temperature.the check engine light is on
RESET WONT SOLVE YOUR PROBLEM.A REPAIR MIGHT!!!WHAT IS YOUR ENGINE CODE LETTERS??
Apr 01, 2014 | 2001 Volkswagen Beetle
My glx china phone is locked password not work
Hi
My mobile GLX c1 locked but password forget so help me to unlock
Jan 30, 2013 | Nokia 6300 Cellular Phone
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
2002 VW Passat GLX AWD, stereo stopped working
HI,
Passats can be reset if the radio is pulled out and the fuse on the back is removed. Wait for 2 mins, reinsert the fuse and turn the radio on. If this doesn't work, please take it to the dealer for the unlocking of the code, for which he may charge you some fee.
Do let me know if it was helpful.
Regards
Kanu
Sep 09, 2009 | 2002 Volkswagen Passat
I have a 97 volkswagen Jetta GLX that is idleing very low
there is no code......unless you're using a vag-com?
have you disconnected the battery recently? or anything of the sort. if so, you may need to align your throttle body. anyhow, disconnect the battery for 10 minutes or more. it takes at least 10 minutes for the ecu to reset, so the longer the better. now, reconnect the battery, as quickly as possible, get in and turn the key to the battery. youll hear a buzzing of sorts from the engine bay if its working. leave the key on battery for 3 minutes. the buzzing will have stopped, before 3 minutes, but after the 3 minutes, start the car. now, let it sit at idle for 3 minutes, dont touch the gas. just let it sit. after 3 minutes at idle, go for a drive and you should be all set. hope that helps.
Sep 03, 2009 | 1997 Volkswagen Jetta
1999 lancer
The GL was a 1.5L engine whereas the GLX had a 1.8L engine plus other types of upgrades i believe,
Jun 30, 2008 | 2002 Mitsubishi Lancer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
