Bosch wae24271au 3yrs old. drum wont turn in any wash cycle, but will fill and drain water. belt checked and brushes good. any more ideas will help us all. :)
2 Suggested Answers
  • 5 Answers
SOURCE: Drum doesn't spin at all during wash or rinse.
TRY TURNING THE DRUM BY HAND IF IT DOES NOT MOVE YOU PROBABLY HAVE A BAD MOTOR IF IT MOVES VERY EASILY YOU HAVE A BROKEN BELT. IF IT MOVES WITH SOME RESISTANCE TRY CHECKING THE VOLTAGE AT THE MOTOR IT BE A BAD WIRE
Posted on Aug 22, 2009
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Sep 23, 2008 | Washing Machines
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
