RCA SRS and Direct TV
Our RCA SRS used to have Direct TV. It no longer has Direct TV but we can not get our cable to work due to the Direct TV setting. How do we clear Direct TV from our set??
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Setup procedure to direct tv is too much to type in here. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Posted on Apr 24, 2013
  • 52 Answers
SOURCE: Tuner Mode - Air or Cable?
Direct tv, unless using there HD service will give a pretty crappy picture for high res displays. So if you spent the money on the set, spend the extra $9 a month for there HD service.. Is well worth it.
Posted on Apr 21, 2008
farr64
  • 121 Answers
SOURCE: connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Posted on May 01, 2009
  • 7 Answers
SOURCE: FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Craig
Posted on May 08, 2009
DerStrom
  • 103 Answers
SOURCE: Would like to use Direct TV remote instead of Olevia remote
Try the following steps:
1. Turn on the tv. 2. Slide the "Mode" switch to the "tv" position 3. Press and hold the "mute" and "select" keys at the same time until the green light under "tv" flashes twice. Release both keys. 4. Using the remote's keypad, enter the digits 9-9-1-1 5. Press "pwr" key. Point the remote at the tv. 6. Repeatedly press "channel up" key until the tv turns off. 7. As soon as the tv shuts off, press and release the "select" key Your remote should now be programed to the tv.
All of this information came from the link below. If you have any more questions, this link may be able to answer them for you:
www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC64forWeb.pdf
Thanks for the question, and good luck! Sincerely, Der Strom
Posted on Apr 12, 2010
  • 8457 Answers
SOURCE: hdmi ports are not working
That HD mode.That good what else do u want.Unplug,replug the tv an hour later,might get HDMI ports work again.Not,ur Tuner board is dead.
Posted on Apr 26, 2010
Element tv code direct tv
Not following... This is what I think you may be saying: You can't get the TV to use the RCA input?
The reason for my confusion is "rca surround sound". RCA will only carry left and right channel (stereo). It can't push surround sound unless it's setup as a direct input [typically an 8 channel input, where you would have 8 RCA cables (or 4 pair) connected].
The headphone jack, if using a 4-pin headphone jack (it has 4 sections of metal, vs a 3-pin, which only has 3 sections of metal), may be able to send something closer to surround sound, but it wouldn't be a true surround sound. You would need to use fiber optic, HDMI, DVI, or digital coax cable.
The sound settings in the OS on the computer need to be set to push the surround sound, or it will only push stereo. You'll probably need to spend some time there testing all the setting options.
Oct 19, 2013 | Computers & Internet
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
I can not program the tv with the cable, which input goes with the cable channel. I have a 32 inch RCA with SRS . HELP
I do not see a question. "Which input goes with the cable channel?" Don't understand. Is there a cable box or SAT box connected to the TV? What kind of cable is running to the TV from the source? If you just have the coax cable going from the wall to the TV, then you need to auto format the channels. Select menu on the TV remote. Find Sources or Cable. Select "Cable" not "Air". Select Auto Format. May take several minutes. Input selector from TV remote should be "TV".
Jun 30, 2010 | RCA Televison & Video
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Direct TV Hookup
please help my remote has change language and jumping chanel and pause on mute
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
