Question about ICOM Informatique Icom IC-F21 16ch UHF radio
I have the software and the cable.
The F-21 radio worked and I got the frequencies. The F21GM radio won't communicate. What would be the problem?
    Master:
  • 623 Answers
Be sure your computer baud rate is set to match what the radio is using.
Posted on Nov 07, 2013
2 Suggested Answers
SOURCE: IC A23 Portable VHF radio Locked
ic a 23 quero scannear como fazer /???
please scam mode /???
Posted on Oct 15, 2009
Yeasu 270r help with frequency entry. Not showing numaric 6 digit frequency number
Google RT Sytems Software and go to their website and purchase the programing software and it will come with a cable for your model of Yaesu radio and use your computer to program this handheld and be done with it. Only $49.95 and the best money you will ever spend. Programming handhelds from the keypad is a total waste of time. RT SYSTEMS SOFTWARE
Mar 11, 2017 | Radio Communications
Radio Shack personal transceiver to pair the
there is no "pairing the signal frequency" these are fixed frequency single channel radios . they cane with only one frequency available and every one worked with every other one.
Sep 03, 2014 | Radio Communications
Walkie talkie frequencies
The Midland LXT328 is a FRS/GMRS radio and can communicate on 22 different frequencies. Here is a list from radio reference:
Channel/Frequency
1 462.5625
2 462.5875
3 462.6125
4 462.6375
5 462.6625
6 462.6875
7 462.7125
8 467.5625
9 467.5875
10 467.6125
11 467.6375
12 467.6625
13 467.6875
14 467.7125
15 462.5500
16 462.5750
17 462.6000
18 462.6250
19 462.6500
20 462.6750
21 462.7000
22 462.7250
Sep 11, 2013 | Midland LXT328 Two Way Radio
How do you change the channel on the AXU4100
Here is a link to the user guide, where you will find the available built-in frequencies, and instructions: http://acsspirit.com/brochures/ax_user_guide.pdf
You can also take your radio to a Motorola dealer and have them program it (custom) using Motorola software and cable designed for this style radio.
It could be as simple as enabling a private line code (PL code) in the radio. You may not need/want to change frequencies. Adding a PL code would block out other users on your frequency. You would not hear them, despite them still being there.
Best regards.
Dec 19, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
I have programmed my pro164 scanner using win97 software and the pc patch cable. i have frequencies programmed to channels onto bank 0. i also programmed the desired talkgroups onto bank 0. problem is when...
you will have to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ .
but if you have tried doing this.i advise do it again.again run the program by connecting the cable again.if you have not tried it then do it again. if still the same problem.then it might be the problem with the scanner.get it rechecked from radio shack. there are many many users facing this same problem this particular model of radioshack scanner and other model in which this same problem occurs is pro-197. get it checked with radio shack.tech. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 27, 2010 | Radio Shack Pro-97 Handheld Scanner
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Pro-164 scanner stops receiving when Motorola talk-ids are progra
I had to buy the Radio Shack USB cable 20-047 and install
Works like a champ !!!!!!
Dec 31, 2009 | Radio Shack Pro-97 Handheld Scanner
Problem with Vertex VX-820
Try "reading" the radio before programming it. It sounds like the programming software is using the settings from one radio to write to another. It's highly probable that the firmware is different on the two radios.
It's always a good idea to "read" a radio befor trying to 'write' to it..
Dec 14, 2009 | Vertex Radio Communications
Motorola SP50 Programming
The SP50 is dealer programmable. The software, cable and RIB (radio interface box) are necessary for programming this unit. If you are needing to match an existing unit, you can have the radio programmed at your local dealer or by shipping your radios to a service center. (Typically $15 to $25 US)
When looking for the second radio, be certain to get an SP50 with the same model number as your existing unit to ensure they will work together properly. Model numbers beginning with P93 are VHF and P94 are UHF.
May 06, 2009 | Motorola Talkabout FR50 (14 Channels)...
Configuring audiovox GMRS1072CH walkie talkie
With the issue of 240V if the charger has not a Voltage switch, you will need to find another charger/transformer with the same Voltage/Amps ouput that works with 240V.
For Vox operations, this feature works independly form channel, you should choose the channel# and code # first, to match both radios, and get them communicate, then the Vox feature.
In Some radios the VOX feature works with an external audio accesory, in other radios works with out it.
Basically if this radios works without it, you should see that the radio transmist by itself when you speak direct to the radio, and stops transmiting 1 or2 seconds after you stop talking.
Good Luck.
Nov 20, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
ICOM Informatique Icom IC-F21 16ch UHF radio Logo
71 people viewed this question
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
barney2xbass
Level 1 Expert
normis101
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
