Question about Cub Cadet Garden
Stripped spark plug - Cub Cadet Garden
  • Cub Cadet Master
  • 7,482 Answers
Hi Anglee
You will need to use a helicoil to replace the stripped out threads.
You can get them at most auto parts houses.
I will send you to youtube to see a video on how to use a heilcoil to repair your stripped out spark plug hole.
Bud
Posted on Apr 24, 2013
How to repar stripped spark plug threads/ where to purchase?.......???????
Helicoils are the best "at home" repair I know of for stripped spark plug threads in a head.
http://www.stanleyengineeredfastening.com/brands/heli-coil/screw-thread-inserts
Sep 11, 2014 | Motorcycles
Fixed coil on 2002 expedition, now spark plug was stripped or blown out now need to get new spark plug in
There are kits for stripped out spark plug
threads in the cylinder heads
Google the issue, lots to read
Aug 23, 2013 | 2002 Ford Expedition
BEST WAY TO REPAIR A STRIPPED SPARK PLUG
a auto parts store has a heli coil kit that will replace the threads just bring the plug with you
Jun 14, 2012 | Garden
Spark plug stripped
a auto parts store has kits to repair them called a heli coil kit bring the spark plug with you
Spark plug tube striped spark plug jumped out of tube
The issue seems to be related to the spark plug threads. The spark plug is either not tightened down or the threads are stripped, and during the compression stroke when pressure is applied inside the combustion chamber, the pressure leaks thru the spark plug threads and blows off the spark plug boot. If the spark plug is not tightened and the threads are ok, then tightening the plug will resolve this issue. If the spark plug threads are damaged, then the threads will need to be repaired, and will require the cylinder head to be removed to repair the stripped threads. Taking the cylinder head off requires the engine's top end to be ripped apart and re-assembled....big job.
Nov 26, 2010 | 2004 Dodge Stratus
Stihl BG 75 blower doesn't seem to have any spark
These units are very promt to gas fouling of spark plugs, try replacing plug. If you still have no spark then possibly the flywheel has a metal strip in it that is prone to rusting, especially if unit does not get used alot, can be cleaned up with 180 or 22 grit sandpaper. If this strip is rusted then coil cannot communicate & therefore you get no spark. Lastly if all above check out good then most likely you have a bad coil. If coil is to be replaced make sure to gap the coil away from flywheel by placing a peice of paper folded over between coil & metal strip-(magnet) coil will pull itself to strip, tighten bolts & remove paper, gap is set.
Nov 10, 2010 | Garden
Spark plugs are stripped
Yes, go to auto parts, and tell them you need a spark plug hole repair kit, very easy to install, just follow the directions.
Jul 22, 2010 | 1995 Geo Prizm
Spark plug pop out when warmng up and wat tighten
Either it is the wrong spark plug or you have stripped threads.
If the treads are stripped, you can buy a kit to fix it or re-tap the hole. Worst case scenario, you need a new head.
Nov 18, 2009 | 1999 Honda CBR 900 RR Fireblade
Garden Logo
80 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
