Question about Casio Parts Cash Register PC Desktop
Can't get clerk button to work after ram clear and initialize
The only code I can get the Casio CE 4115 to accept after a ram clear is 1215, but then my clerk button won't work.
Also forgot codes for programming departments and codes to add functions to keyboard.
  • sales427 Mar 16, 2009
    Thanks
    I know of several models that have the same Macking Code or similar.
    If anyone has heard of the C E - 4530 or the T K - 1200 and has the codes for them, they may work.
    I will try the suggestions given, and let you know if any of them worked.
    Thanks
    Joe Hix
  • 737 Answers
Hi.
This is a rare model, so I don't have MAC codes for it. Do you have the initialising table? Is that how you created the code?
In the CE-4000, the second to last digit is Clerk control, so try 1205 or 1225 or 1245
Posted on Mar 13, 2009
I keep geting an e03 error on my casio ce-3400 no matter what i do
You may have switched clerks during a sale. Press the other clerk buttons and see if it works on any other ones.
Sep 17, 2012 | Casio Parts Cash Register PC Desktop
I have a Casio CE-6100 cash register. Whenever I try to finalise a transaction with the "Cash" button i get a long beep and nothing happens. If i use the cheque or credit card buttons instead...
You may have changed the key feature settings for CASH accidentally. Try this:
Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
Turn key back to REG mode and try it - you may have to sign a clerk on
If anyone needs more information, the Casio CE-6100 manual is here:
CE-6100 programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
CE-6100 user manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-6100_users_manual.html
Aug 18, 2011 | Casio Parts Cash Register PC Desktop
Casio TE2200 stuck in INIT mode and wont let any cashier log on. I have just done a factory reset and set time, date, dept names, and cashier names. Now no-one can log on or off and it seems the till...
It sounds like you might have used the wrong clerk system in your MAC code. If you use a single clerk button on keyboard, you need clerk code set in the MAC code. If you use the clerk buttons at the top of the keyboard, you need to set clerk key in the MAC code. If you tell me the MAC code you used during the reset, I can see which system you are using.
If anyone needs a Casio TE-2200 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jan 16, 2011 | Casio Parts Cash Register PC Desktop
How to set up 4 clerks on the key board of casio tk2700 cash register to be used as multi user
The 2700 has to be set to sign on clerks straight after a RAM clear if you want this feature, otherwise you use the buttons next to the mode key to change clerk. Try the buttons first to see if they are changing clerks. If not, then you can have sign ons. If they are, you are stuck with this unless you clear the whole machine and start again
Dec 16, 2010 | Casio Parts Cash Register PC Desktop
I have a Samsung SER-6540 II register. An error occurred that locked it up. I am not sure what the clerk did. I unplugged and turned the key to "P" and held down "Cash" key to clear. Now the register reads...
Ok. that's good. You have performed an initial reset that does not lose any data. You must log back on after an initial reset. <div>Find the button marked clerk, clk#, cashier, cash# or similar. This is your log on button. Now type a clerk code (default is 1) then press the cashier button.</div> <div><br /></div> <div>-------------------------------------------------------------------------</div> <div><br /></div> <div>If anyone needs a Samsung SER-6500II or SER-6540II manual, c-tech has them here:</div> <div><br /></div> <div><a href="http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php">http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php</a></div>
Aug 27, 2010 | Casio Parts Cash Register PC Desktop
My problem is I could not able to log in to the cleark E008 cash register casio ce-6000
There are two ways to log a clerk on. Firstly, try the buttons next to the key. If the machine has been programmed to use these buttons, then pressing one of them will log you on. Otherwise, it is done by code. The default for clerk 1 is code 1, so you would press 1 then the CLK# button. If a different logon number has been programmed, then you will need to know it to log on.
Dec 05, 2009 | Casio Parts Cash Register PC Desktop
Casio ce-3700 h2o dmg
Hi.
Error8 on Casio registers means you are not logged on. You need to log a clerk (operator) onto the machine (either press one of the clerk buttons near the key, or use the PIN number and clerk button if you have codes for log-on). If you can't log-on, then you have probably contaminated the keyboard membrane sheets inside the keyboard, and they will need to be dried or repaired.
Mark
Mar 01, 2009 | Casio Parts Cash Register PC Desktop
Casio CE-3700 giving E008 errors!
Hi.
Yes, it definitely is the CLERK function. When you enter 0 CLK#, you are just logging off (which has already been done), so that is normal for it to accept that. If you can't get in with 1 CLK# then I'd say someone has setup special codes for this machine (PIN numbers). You will need to do a prog. read. Also, if you have four raised CLERK buttons just below the keylock, one of them should be pressed down. (they are an option on some versions). Try 1 CLK# or 2 CLK# or 3 CLK# ... up to 7. If none will log you on, let me know, and I'll tell you how to do a read on it.
Mark
Apr 30, 2008 | Casio Parts Cash Register PC Desktop
Casio CE-3700 cash register MAC instructions
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
Apr 15, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
116 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
