Question about Sewing Machines
My down stitch is not perfect
My machine stitch is not perfect down stitchis very loose
  • 29 Answers
Rethread your machine and make sure the thread is properly in the tension disk. Tighten the tension a little at a time once you are sure everything is threaded properly.
Posted on Apr 25, 2013
4 Suggested Answers
  • 69 Answers
SOURCE: I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Posted on Feb 07, 2009
  • 1564 Answers
SOURCE: My top stitch is loose on my singer
Tighten your tension for the top thread.
Posted on Aug 05, 2012
SOURCE: Lower Looper are loose
depending on the fabric sewed, sometimes the tension has to be
adjusted. when sewing on a project cut a scrap piece from the fabric
being used, as you sew then you can check to tension to see if
it needs to be tightened or loosened.
do you have a manual for the machine?
also try new needles
Posted on Aug 24, 2012
When stitching on my Juki 1541 the top stitching is perfect but the stitching from the bobbin is loose. how to fix, I did try sighing the screw on the bobbing , did not work please help!!!!!!!
When the bobbin stitching is off the problem is usually with the top thread. Unthread and rethread the machine making sure it is threaded correctly and is securely in the tension disk. If you still have trouble try using a new needle.
Jun 01, 2017 | Juki Sewing Machines
Top stitch looks perfect but bobbin stitch lies flat.
what you describe indicates that the needle thread tension is too loose
it is not pulling the bobbin thread up and that is creating the birds nest under the material
Dec 12, 2016 | Sewing Machines
I have a pfaff 1475 and i can not get the tension correct. it is very loose on rt he bobbin side and perfect on the top side. HELP
......... when you did the bobbin drop, did it drop some then stop? Is the bobbin in the correct way (can go in two ways - thread feeds differently into / under the tension 'finger')
Jul 03, 2015 | PfaFF Sewing Machines
Machine not working as normal
it's possible there could be a loose or broken part in the machine, and the cam that does the zig zag could be worn or damaged.
having it checked would be a good idea.
Apr 03, 2014 | New Home Sewing Machines
When I embroider with my Pfaff Creative 2 the top tension pulls bobbin thread up too much. I changed toe tension on top but it still does the same thing. How can this be fixed?
Suggest you do rethreading ,then test the stitches on straight stitch. If top stitches is loose you have to reduce the upper thread tension, if the bottom stitches is loose you have to increase the upper thread tension. Adjust accordingly till you can get a perfect straight stitch. If okay then you can continue your embroidery work.
Oct 31, 2013 | Sewing Machines
Aug 23, 2012 | White Sewing Sewing Machines
Aug 03, 2012 | Singer Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Stitching problems with my sewing machine
Make sure first of all that you have a perfect needle in and the correct way round, failing that you may need to retime the machine, if you email me I will attach instructions.
drivewithken@blueyonder.co.uk
Jun 26, 2010 | Sewing Machines
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
