Question about LG 60PK540 Plasma TV
Replaced power supply lg 60pk540 wont turn on
I replaced power supply, TV won't power up
ronaldo_ross
  • 1056 Answers
SOURCE: My son dropped my 32'' inch LG lcd tv now it won't
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
Posted on May 28, 2011
ekcnoel
  • 998 Answers
SOURCE: LG tv won't turn on.
This trouble is very common for lcd if you remove the back cover of your tv try to look for bulge up in the top of the capacitor or not perfectly flat like the others or if you see something with a wet mark at the bottom of the capacitor try to replace them but be sure to remember the proper position of the capacitor because it has a polarity, When this capacitor has a bulge up or leaky it will not properly filter the dc voltage and it cannot transfer properly the dc voltage to other parts. Note be sure to unplug your unit first before removing the back cover, good day and best regards. Feel free to send feed back.
Posted on Jul 25, 2011
SD Tech
  • 14553 Answers
SOURCE: Lg tv won't power up
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_29_2012_1_32_51_pm.jpg
Posted on Apr 29, 2012
SD Tech
  • 14553 Answers
SOURCE: Lg lcd 32' won't turn !
I see so many here with no sound/no picture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 10_30_2012_11_13_33_pm.jpg
Posted on Oct 30, 2012
Has power but no screen display
Blown fuse in power supply, small chip fuse, one of the DC fuses.
Apr 14, 2014 | LG 60PK540 Plasma TV
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
How do i replace the fuse and where is it located
The fuse is on the power supply inside the TV, But it is most likely that it won't be the issue, the fault will most likely be a component failure on one of the circuit boards.
Mar 10, 2012 | LG 50PK550 50 in. TV
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Mar 07, 2012 | LG Televison & Video
My lg 32ld350 turns off on its on and wont turn back on
Hello
Replace the T-Con board. It is faulty.
9_29_2011_2_57_41_am.jpgThis is the picture of the T-Con board that you have to replaced. Buy it from LG aughotised service center only. OK.
Sep 28, 2011 | LG 32LD350 32 HDTVReady LCD TV
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
My 37" lg hdtv lcd
Their are a lot of things that could be wrong with your TV. The most commond would be your power supply or your signal board. If you look at your power supply carefully, You might see some capacitors that look like they blow up. If that's the case then replaceing them might fix your problem if not then you might have to get a whole power supply. You can get parts for this TV at www.interliquidparts.com
Jun 08, 2011 | LG 37LH20 37 in. LCD HDTV
LG 60PK540 Plasma TV Logo
191 people viewed this question
