Compaq presario freezes
Okay full problem is, if I leave it over night online it auto shut-offs and the I have got to reboot the thing 3 times for it to start up. Then when I load to many things like a game and a browser or I close a large game it freezes and again I have got to reboot it.
  • Computers & ... Master
  • 5,660 Answers
1) See if it is dirty inside.
The hardware components inside are cooled by air. The Processor (CPU) has a finned Heatsink sitting on it. The fins of the Heatsink absorb the heat from the Processor,(CPU); and radiate it away.
Air flow from the CPU (Processor) fan, helps carry heat away from the fins of the Heatsink.
When a Processor becomes too hot, (Exceeds it's thermal limit), it turns off. (BIOS turns it off)
This is a fail safe feature that is built-in. Keeps the Processor from burning up.
When the computer case fans get clogged with 'Gunk', and the Processor fan does the same; plus in-between the fins of the Heatsink; the cooling capacity of the cooling system, drops tremendously.
Also;
This is a general view of a top of a Processor,
http://www.cpu-world.com/CPUs/Pentium_4/index.html
This is a general view of a Heatsink/Fan combo, to illustrate the bottom area of an average Heatsink,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7151732&CatId=493
Under the Main view are smaller views. Hover your mouse cursor on the small view all the way to the Right.
(Has a Thermal Pad already installed on it. A Thermal Pad is JUNK! More on this later. Look at the surface around that square Thermal Pad in the middle )
The top of a Processor, and the bottom of the Heatsink; are not perfectly smooth.
A magnified view would detail, 'Ridges, Valleys, and Pitholes'.
When the two parts are mated together, Air Pockets are formed. Air in this case is an Insulator; not a Conductor.
Thermal Paste fills the above imperfections, and is an Excellent conductor of heat.
After time (Age), and constant overheating, the Thermal Paste dries up. Looses it's thermal conductivity properties.
Replace the Thermal Paste.
A Thermal Pad is a material that is impregnated with Thermal Paste. As stated, they are Junk! Carefully peel off, removing as much as you can.
Then I use an old credit card, and scrape off as much of the Thermal Pad residue; as I can.
Follow with Q-tips dipped in Isopropyl Alcohol. (Rubbing alcohol)
91 percent or higher is best, but 70 percent will do. 50 percent = No IMHO; because it is now 50 percent Water, and 50 percent Alcohol. You want it to dry up quickly, and have strength to cut the old Thermal Paste, or Thermal Pad residue.
Yes. It usually turns into a gooey mess! Takes a LOT of alcohol soaked Q-tips. How clean? Clean enough to eat off of.
CAUTION!
Isopropyl alcohol is EXTREMELY FLAMMABLE!!
Use in a well ventilated area, with NO sparks or flames present.
Thermal Paste is treated the same way. Scrape off as much as you can, use Q-tips dipped in Isopropyl alcohol.
Now PROPERLY apply fresh, new Thermal Paste.
Example of Thermal Paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 24, 2013
  • joecoolvette
    joecoolvette Apr 24, 2013
    Forgot to add; FOLLOW Anti-Static Procedures. If you do not know what these are, post back in a Comment. DO NOT reach into your unplugged from power computer, if not following Anti-Static Procedures.......
  • 161 Answers
SOURCE: Presario s6500nx stops loading at set up screen
sounds like you have board problems.
unplug everything from it first and see if this helps could be something you have plugged up could be bad too.
you will have to open box and look for damage and then one by one unplug something and then reboot to see what it might be.
Posted on Aug 03, 2008
  • 8 Answers
SOURCE: at start up my computer reboots 2 or 3 times
Hi there!
Try running on safe mode. Here's how you do that power on your PC press F5 continuously untill you see the boot menu and select safe mode. from there run the following: antivirus, checkdisk and spyware removal. hope it helps.
Posted on Mar 18, 2009
tbirdfan1
  • 3051 Answers
SOURCE: compaq presario wont turn on
Hello there:
when you turn on the computer and look at the back of the power supply and see if the fan is even working and blowing air if not you will want to remove the power supply and either have it tested or replaced there is a linkable fuse in these depending what type you have this fuse may be soldered in place or it may be able to be removed and replaced. ok i hope that this is helpful as what to do.
please dont forget to rate my solution for you.
best regards
mike
(USN) RETIRED
Posted on Aug 04, 2009
SOURCE: Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Posted on Sep 04, 2009
  • 4234 Answers
SOURCE: COMPAQ PRESARIO S5200NX WON'T START - Press start
Make sure that the CPU fan is clean and free to turn. The main fan should have a connector with 3 wires. Two are for power and the third returns the fan revolution count. If the fan is not being seen as spinning, the system will shutdown.
Dan
Posted on Nov 06, 2009
Compaq presario shutdown
you might need to replace the monitor
Sep 21, 2013 | Computers & Internet
Compaq Presario CQ56 freezes
Well the best thing to do is to start testing your hardware, you could have a problem with your hard drive, or your ram, or your video card, or your usb ports or cable's. You can make diagnostic cd's easily by using these free downloadable utilities:
http://www.memtest86.com/download.html This utility is a classic and works great for testing the ram in your computer.
http://www.seagate.com/support/downloads/seatools/ This is a seagate hard drive diagnostic utility that works on all types of hard drives to test that part of your computer.
http://mikelab.kiev.ua/index_en.php?page=PROGRAMS/vmt_en This is a video card testing bootable image.
If those pass, you can disable the usb ports on your computer from your bios potentially, and or crack open your computer and disconnect them if they are connected to the motherboard with cables :)
May 14, 2012 | Compaq Presario CQ56-115DX Laptop
My laptop keeps freezing and I have to shut down and reboot it several times
check your laptop in safe mode scan it through a updated antivirus or if this does not solve the problem do a fresh installation of OS or check the RAM
Sep 04, 2009 | Compaq Presario Notebook
Desktop freezes up so often or gets logout by itself & reboot?!
This could be a couple of things, overheating may cause it to randomly shut down, but if it freezes up on you then it could be a motherboard issue or memory. When you boot up your computer, does it beep at you at all? More than 1 beep signifies a problem. Right click on the my computer icon and click properties, see how much memory it says you have, does that number look accurate? A bad memory module could cause similar problems. A bad motherboard would, in my experience, more often freeze when you first boot up.
Mar 12, 2009 | Computers & Internet
Skype
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Jan 21, 2009 | HP Compaq Presario V2000 Notebook
Okay my compaq presario f700 keeps turning its self off if its in high performence and its really annoying because when its on power saver it is slow. do you know what is wrong with it ,if so can you get...
The question is a little vague, but if its running under stress and is shutting down, then its likely to be overheating and the unit is protecting itself.
Get a can of compressed air (or a vacuum cleaner, if you dont want to cough up) and clean the heatsink and fan ports.
If its not this, and you mean it keeps going into standby, either switch this off in Windows (Start -- Control Panel -- Power options) or go into your Bios and see if there is an option in their.
You can also usually switch off the 'CPU stepping' and leave it on full speed all the time (battery life will suffer).
Jan 12, 2009 | Compaq Presario Notebook
When I am online and watching any type of video, my compaq presario laptop completely shuts down. Powers all the way down on its own. It does not reboot. It stays off until I reboot.
Run your virus programs to check for infections. Install the most current driver for your video adapter. If that does not help unplug and re-plug in your video card. Finally replace your video card.
Aug 24, 2008 | Compaq Computers & Internet
Compaq Presario V3019AU freezing.
i think this is a motherboard problem
Nov 05, 2007 | Compaq Presario Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
