Question about Dryers
Water damage ceiling in mobile home - Dryers
    Genius:
  • 1,148 Answers
Whats the extent of water damage,,still leaking,,or not?,,if just small water stains or even big ones ,,u can get some stain blocking primer to roll on ceiling,,if small places get in primer in spray can,,home depot has gripper its really good,,any of questions shoot me a messege,,with more info,,also i remodel homes and im a painter,,just so u no,,thanks
Posted on Apr 25, 2013
  • Tina Mcmurry Apr 26, 2013
    Josh,yes ceiling still leaking when it rains . Almost have skylight that shouldn't be there.
Why does Lowes in Lawton OK not carry complete inventory to complete projects?
They don't have room for everything,most stores now will have to order for you,did you try Home Depot.
Jul 04, 2017 | Home
Tip
How to fix wter damge mobile at home
HI
i am telling you (HOW TO PROTECT MOBLE FROM WATER DAMAGE) now a days the water damge is common byut hoe to manage this is the main problem
SO,
when you suffering from water damge just calm down and one thing that after water damge dont rty to switch on the mobile just open the back panel and remove battery ,sim card and sd card NOW take a air tight container take some rice and put it into the container and and mobile also and close it tightly levave it for 45 min and afetr some u will see that most the water get absorb by the rice noe just take it to the shop and afetr this your mobile will be save and able to acces by you THANKYOU
on Jun 22, 2015 | Apple Iphone 3gs 8gb Black At&t Smartphone...
Bathtub with shower above my bathroom is leaking water by drips through my ceiling into my bathroom in floor exactly under it. Woman told me a plumber used a snake to get a ball of hair out of pipe
You'll have to cut out a section of the ceiling around the leak (suggest 1' x 1') and see what's damaged in the drain piping. Look for a crack in the pipe or trap, then saw out the broken section and replace. Replace the drywall, tape and repair, then paint the ceiling.
I had this problem in a newer house that turned out to be a loose drain fitting -- just not tightened up fully when originally installed.
May 26, 2017 | SHE Home
How wiring a new ceiling fan in a 1995 mobile home that is controled by a wall switch and controls 2 fans
Should be Bk &Blue(wirenut togerher) - bk, white - Wh, Green - green
Aug 28, 2014 | Dryers
I have 3 black, 1 tan, 1 gray wireing from ceiling. I have a wall switch that controls 2 ceiling fans in a mobile home . i want to connect a new ceiling fan that has 1 black, 1 white, 1 blue wireing.
The gray tan and the other wires usually have plug on the end and the plug into the fan unit when it's put together . The part the mounts to the ceiling should be blue black and white
Aug 28, 2014 | Cars & Trucks
How do i fix old, cracked, weter damaged walls and ceilings
You will need to figure out if moisture is from some type of plumbing leak or a leak from the exterior of the house.(roof, window, etc.). You need to fix the moisture problem first. It could lead to mold issues that could make you sick. Not to mention it will only ruin the new patch work. If the damage is only a couple of small spots in each room. You can then cut the damaged areas out and put new drywall patches in. Home Depot sells drywall in 2ftx2ft sections. Measure the damaged section. Example. damage is 2inx2in.Cut the new drywall 3inx3in. Take the 3x3 patch trace around it on top of damaged area. Take a razor knife cut around line and break out the damage area. You may have to screw wood around the inside hole. To be able to screw new patch in place. Then take mesh drywall tape around seams and then mud. Any hardware person should be able to help. If you are not comfortable doing this please call a handyman service or local contractor. Hope this helps .
Feb 22, 2014 | Tools & Hardware - Others
Everstar mpm2 10cr bb6
i forgot my gmail account
May 31, 2013 | Computers & Internet
I want to install a ceiling fan in my mobile home but are not quiet sure how to go about doing this as there is no electic box on the ceiling
First thing is you are going to have to get a ceiling fan mounting box and have it installed in the ceiling...these are specially built to support the weight of most ceiling fans. then you are going to need to wire it either to a switch on the wall or run it back to the electrical panel. Depending on where you live, you may need to contact your building department to see what the electrical code for mobile homes is and if you can even do the work. You may find that you need to be licensed for this type of work.
Jan 08, 2011 | Dryers
Surface mount ceiling fan
Try a mobile home supply house
Oct 13, 2006 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
