2004 Jaguar X-Type Logo
Posted on Mar 12, 2009
Where is oil filter located on jag xtype 20l desiel,
my head light stopped working I think I have switched a button off in the car
  • Anonymous Mar 20, 2014
    sidelight bulb xtype jag
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
813
Points
6
The oil filter is at the front of the engine under the plastic belly cover, it is of the paper type hope this halps you out.
Keith cockrill
Level 1:
New Friend:
  • Posted on Dec 12, 2014
 Keith cockrill
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
720
Points
The filter is on the frunt of the engine behind radiator. You need to remove the under tray from beneath the car first. The filter is a paper element in the aluminium casting. This casting has a black plastic base that unscrews. Unscrew this plastic base a few turns which will allow the filter to drain before removing completely. Remember to replace the o-ring and oil the new one before replacing the element and screwing the base back in place.
Where does the oil filter on a ford ranger 2.2 desiel l ocated
Tools/things you'd need and tips to change oil filter:
1. 27mm socket spanner
2. Lots of rags
Access is from the N/S/F wheel arch. By the axle
You need to remove the wheel first.
Next, with the 27mm socket spanner you have to remove the filter housing.
Then, remove a couple of clips holding the rubber liner in place.
Once removed, you can gain access to the oil filter inside.
Now, before the entire process, make sure you pack lots of rags to trap/capture potential oil spillage on engine parts, axle, etc.
Hope this helps you out
I had asked a question about a month ago .... Why does my ac on jag 2003 xtype only blow cold when driving but when I stop at stop signs, red lights , whatever pleas call me 405 8754331
Your question does not make sense, If you mean when you stop at stop signs etc it does not blow cold?
My answer in this case is that the electric fan's second speed for the aircon is not working. Get it checked
Cambelt timing marks 4jx1
sounds like the injector sleeve O rings have failed this was common.
if you put a clear plastic piece of hose on supply line for diesel fuel filter to head fitting at front and fuel is not black but normal diesel colour thats good.
then put clear hose on return line fitting at rear of cylinder head and fuel is now darker, engine oil is by passing injector sleeve top O rings and entering into fuel gallery in head.
rocker cover, injector rail, injectors need removing and injector sleeves need replacing as well as O rings and seats.
a special tool is needed to remove the injector sleeves out of the head. you will also need to drain the cooling system before removing the injector sleeves, so coolant is also needed.
dealers have special tool for injector sleeves
I have a 2002 jaguar xtype 2.5 liter ..both my engines lights are on dont know what the problem ..when i wash my car both engine lights turn off , but when i turn the car on my engine lights turn back on...
Were the spark plugs change in it ? Did he check for bad fuel Injecters, Word of advice ,When you own a jag, don,t take it to joe boy the (mechanic) You take it to the (Dealer) Ship, In the long run, It will cost you less ,Then useing joe the mechanic, What does not have a clue about working on a (jag) What to look for when there is a (Problem) With it, One of my nepwews fround that out the hard way when he had a 2005 ,Jag, It penny him to death, In the 2 years that he own the car,
Jag xtype engine light lit
the engine light wont turn off unless the issue is resolves because it iis operated through the CAN ..
12helpful
Jag xtype 2.0D 2004 Glow plug light flashing.Engine malfunction light on .No loss of power.Hhappened just after refuelling
jaguar x-type 2ltr diesel 2004 the glow plug warning light flashing, was told dirty fuel on fault code all fuel changed and filters. No problems for 20 miles untill engine was put under power on high revs went into limp mode, warning light glow plug falshing again? any ideas thanks.
Can't get cap off coolant tank xtype jag.
It must be extremely tight or cross threaded. try spraying some penetrating oil into the threads and leaving it for a while, then apply a lot of torque and try turn it off. You may have to replace the tank if the treads are damaged.
2answers
2003 X-Type: i want to buy a 2003 jaguar xtype with only 41,000...
I purchased very similar here in the UK £4800 (trade) two years ago, only problem so far has been O2 sensor failure which I replaced myself but was still fairly expensive. Other than that car has been good. Check for Jag service history
Where is the air filter located on 02 jag xtype
follow the breather plastic hose probably blck in color and it should go back close to the right hand side headlight. There will be asort of box it connects to and you will need to remove 4 screws i believe. Under that is the breather. Thats where I find it on most vehicles so please know I am guessing here and leave me a good mark for trying. Thanks, Raz
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
