Question about Kenmore Dryers
Dryer makes continuos knocking while running - Kenmore Dryers
  • Kenmore Master
  • 7,482 Answers
Hi derik
You did not mention what model dryer you have so I included the info of an older front load dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Posted on Apr 24, 2013
My whirlpool model no 6alsr72 washing machine makes a knocking sound on agitation
remove any clothing restart empty run cycle if still knocks its needs to be re leveled
Feb 06, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Kenmore dryer, model 417.84052500 make a very loud noise like metal on metal when it runs...gets worse the longer it runs
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 04, 2011 | Dryers
Dryer makes banging noise
heatman101
uioiotusdds
Jan 30, 2010 | GE DBVH512GFWW Dryer
Dryer makes clicking noise when running
heatman101
w56w
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When dryer is running it makes a knocking noise
you say when dryer is running it makes a knocking noise, usually, your rollers which is beneath the drum will cause that to happen, replace your rollers
Aug 07, 2009 | Kenmore 73952 Gas Dryer
My Amana dryer LEA30AW makes a loud knocking noise while running and then shuts down. There is heat. It seems to be worse with a larger load. Any ideas??? Thx
heatman101
fo
Jun 08, 2009 | Amana NDE2330AY Electric Dryer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
