Question about HP Compaq Presario C502US Notebook
Presario notebook Down loaded some Vista programs and now when I close my lid it does not go into sleep mode anymore.
  • stone97 Mar 13, 2009
    thank you for trying but for some reason my sleep button still does not work
    Scholar:
  • 77 Answers
You need to tweak your power options to get this functionality back, these options are found in the control panel under power options.
Posted on Mar 12, 2009
Toshiba Satellite L300D. Laptop will come out of sleep or hibernate mode without prompting and display the login box.
If the login box is displayed when it wakes up, that is usual. It uses a sensor to detect when the lid id open and will come out of standby when it thinks the lid is open.
Re configure the power off settings to avoid standby or sleep mode when the lid is closed.
Feb 16, 2014 | Toshiba Satellite L300D-ST3501 Notebook
Asus eee pc shuts down when lid closed
Click Start/Control Panel and check the Power Options settings.
Apr 08, 2012 | ASUS Eee 4G Notebook
Computer re-starts when i want it to shut down or sleep
You should check to see if there is a setting time where the computer installs updates, because the computer may be updating at a certain time and then restarts to finish the update. Check the setting to you might also have the computer restart every so often. hope that this helps.
Jan 08, 2010 | Dell Inspiron 1525 Notebook
Compaq presario CQ50 106CA. When powered on the power light and wireless light illuminates. The DVD sounds like it's initialising and fan runs, but screen blank. Ihave tried all basic fault finding...
Have you tried turning it on and selecting the function key combination for the screen? For example some screens use FN+F7, hold down the Function key and F7 to cycle between presentation modes.
Nov 25, 2009 | HP Compaq Presario CQ50-110US Laptop
When my computer goes into sleep mode it freezes after 5 seconds
There are a lot of systems out there having trouble with the sleep and hibernation programs in windows. The first thing I would do if I wanted to keep the sleep and hibernation programs in place would be to update the BIOS file on the system. I for one am a believe the computer in turning off the sleep and hibernation. They have caused more corrupt windows installations than I care to remember or work on again. If you want to try turning these off for a while and see how the computer reacts, go to the control panel > power option > scroll through the settings and change the way the computer sleeps and hibernates. Also change the setting for what happens when the lid is closed. Change it to "Do Nothing" this will correct a case of the computer not waking up from somply closing the lid. The lcd will automatically turn off when you close the lid and turn back on when you open it...you don't need the computer going to sleep simply because you close the lid for second.
Nov 08, 2009 | Toshiba Satellite A305-S6883 Notebook
I am unable to unhibernate
Power down the computer and power back up. Lets just shut hibernation off...you can always just have the computer sleep...it is much better on the system anyway.
Shutting Down Hibernation
Go to the control panel > Power Options > Hibernation tab > uncheck hibernate…this way you save a lot of disc space and don’t have to go through all the intermittent hibernation problems that occur. After you uncheck hibernation, you can go to the other power options and change how the computer reacts to the lid being closed, when it sleeps and for how long before sleep kicks in. Make sure to change the setting for what happens when lid closes to “do nothing” this will keep the laptop alive even though you close the lid to move it, etc.
Sep 27, 2009 | Compaq Presario 1275 Notebook
Sleep and standby
Well... Sleep and Standby are not the same. While Sleep only turns off a few things, like display, WiFi, and HDD to save energy. Standby saves your session to the Hard Disk, the reason why the laptop seems unresponsible. This is the reason to uncheck Stanby if you want a fast wake-up.
Apr 16, 2009 | Compaq Presario Notebook
ITunes will not play songs on my Logitech speakers
you can disable the sleep mode when you close the lid.
for windows xp
  1. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
for windows vista
  1. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
Feb 07, 2009 | Logitech V20 Portable Notebook Speakers -...
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Compaq Presario 700 PC Notebook keyboard locking out
Check that your notebook power settings are correct, it may be that when you press off or shutdown it's actually going into hibernation or standby, this is only correct when you close the lid without shutting down through Windows. As for Windows Media Player, you cannot remove it as it's a Windows component, you can only dissable it through Add/Remove programmes>Add/Remove Windows Components.
Dec 17, 2006 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario C502US Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
