Leak around Duet wash machine
I have water coming from under my Duet washing machine
  • Washing Mach... Master
  • 15,557 Answers
What side is it on? The front panel under the door comes off. You can then see the pump and drain. If it is not coming from those it could be the fill hose or the detergent dispensor. Also might be the door seal. Location of the leak is important
Posted on Apr 24, 2013
  • 2 more comments
  • John Baldwin Apr 24, 2013
    Front & side
  • Brad Brown Apr 25, 2013
    What is the model number?
  • John Baldwin Apr 25, 2013
    GHW9150PWO
  • Brad Brown Apr 26, 2013
    Did you take the front panel off to see if you can spot anything? This could be the bellows seal on the drum. It is about 120 USD
    Top Expert:
  • 34,169 Answers
Leakage from under a top loader often indicates either that the pump is leaking or there is a leak in one of the hoses
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer has a water leak from under the machine. What could be causing this?
Pull off the lower front panel and watch while washing . You should be able to pinpoint it .
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water leak coming from under my washer wirlpool duet. what would be causing that?
you can remove the bottom panel in front on this unit... the screws are near the floor then that bottom piece can be pulled away... there is a clean out next to the pump assembly run some water and see where water is coming from most likely a hose or pump assemble is leaking ..check all hoses like i said run unit and you should be able to use a flashlight and find the culprit water leak...
good luck to you
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
RUBBER SEAL ON THE DOOR HAS A HOLE IN IT. COULD THIS CAUSE A WATER LEAK THAT SEEMS TO BE COMING OUT THE BOTTOM OF THE MACHINE WHEN THE LOAD IS RINSING AND WASHING????
Yes it will that's a rubber boot that keeps the water inside the machine. You will need a qualified service technician come out to your home to replace that sorry for the troubles hope this helps. Also see if it is under warranty all manufactures offer 1 year warranty unless you paid for a extended warranty.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
check your rubber bellow you might have had something go threw it.
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Nov 10, 2007 | Whirlpool GHW9150 Front Load Washer
Water Leak
When the machine has filled TURN THE POWER OFF.then tip the machine back & lean it on the wall, look around for the leak it should be fairly easy to see. It may be the door seal which has split, you should be able to see this be examining the seal with the door open
Oct 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
