Question about Microsoft Xbox 360 Console
My x box 360 won't work
3 red lights are flashing on my x box 360 when i first turn on my console.
  • 7 more comments
  • Dustin1987 Nov 18, 2007
    Console was only on a few minutes while playing a game and froze up and the 3 red lights came on. Please advise on what should I do.
  • kels5 Nov 24, 2007
    ho do you fix red light problems
  • semperfi23 Nov 24, 2007
    when i turn on my xbox all i get are flashing red lights. HELP ME PLEASE!!!
  • Anonymous Feb 23, 2008
    red light turns on
  • Lawrence Sendejas Feb 23, 2008
    3 red lights flasing when I turn on my 360
  • marty3434 Apr 28, 2008
    i have three red lights and i love my x box but i caint play it help me i paid a lot of money for it so did every x box gamer help in the name of x box
  • ec0039 Apr 29, 2008
    I tried to play a game and my x box froze up. I turned it off and back on and now all i get is red lights and an error message.
  • jay5000 May 23, 2008
    my x-box turns on and then i will put my game in and all i will get is 3 rings of death and i need help
  • Anonymous Aug 03, 2008
    the same **** happend to my 360, 3 red lights what can i do.
You have the RROD (red ring of death). Luckily it is now covered by microsoft warranty so call them up and send it back to be fixed. Alternatively, if for some reason you have no warranty (bought it used, warranty expired) I have heard there is a method to try and fix it by wrapping the 360 in a towel and leaving it on for like 5 or 6 hours. Some people have had success, others just made it worse. You may want to google it to find better instructions as I have never tried it. The most common cause of the rrod is that it overheats and part of the motherboad between the gpu and the cpu warps and they lose connection. So somehow by blocking the vents with a towel and leaving it running it reconnects these joints. However I have heard that it is likely to get the problem again after trying this method, so just send it to microsoft if you can.
Posted on Aug 05, 2007
  • 39 Answers
Follow this link for simple steps on how to fix this problem yourself i did mine and have had no problems since
http://www.youtube.com/watch?v=Sv1kbNePvus&feature=fvst
cheers
Posted on Oct 01, 2009
  • 4 Answers
The towel method is a quick fix, but it's not going to solve the problem. Just open the xbox and resolder the joints with leaded solder. Microsoft was cheap and used solder that just doesn't hold up under the heat the unit produces, causing all the problems we saw in the first generation of 360s that hit the market.
    Genius:
  • 1,093 Answers
If you have the 3 red lights then this happens because the GPU and the CPU have overheated, you will need to send it back or repair it yourself, you should not perform the towel trick
When i connect my battery pack outlet for my xbox it goes to red light and my xbox 360 won't turn on
Hello
1 unlpug power to x box,remove hard drive.
Plug x box back in and reinstall hard drive. Try x box.
2 remove memory cards.Try x box.if it works the memory card was bad.
3 Remove any accesories. Try x box.plug one acc back in at a time.
Sep 19, 2011 | Microsoft Xbox 360 Console
Tip
What to do if you have 3 flashing red lights on your Xbox 360 Console?
If you have the 3 rings of Death (3 Flashing Red Lights) on your xbox 360 console, all you need to do is to contact Xbox Support and report this issue with them. The Console has a 3 year warranty for the 3 flashing red lights. Just make sure you did the following first:
1. Power Cycle your Console (Turn it off, unplug the power adapter from the wall outlet, wait for 30 seconds, turn it back on)**This is the best solution and it usually works!!
2. If still persist, Turn it off, remove any accessories connected to it (Hard Drive, Controllers, etc.) turn it back on without those accessories. **These accessories sometimes causes the problem.
3. If removing these accessories removed the 3 flashing lights, attach the accessories one at a time, every time turning it off and attaching one and turning it back on checking each time if the red lights (any lights) appeared. It will tell you what is causing the error.
4. If all else fails, again CONTACT XBOX TECH SUPPORT on their Toll free number. Make sure that you tell the tech that you have done those things above so they can create a report for the issue. They love the 3 flashing red lights issue. I should know, I am formerly one of them. :)
on Jun 12, 2010 | Video Game Consoles & Games
My x-box360 won't work the red light comes on but
OK, I'm assuming your console has 3 flashing red lights, if that is the case there's not much you can do for the Xbox, 3 flashing red lights is a problem with the mother board in your console, now there is a temporary fix you could perform your self but that doesn't always work, its a 50/50 chance, personally id play it safe on this one and check to see if your warranty is still good, if so all you have to do is contact Microsoft and explain to them about your red lights, they'll then ask you to plug out everything and plug it back in, when that fails to work they will send you out tags in your e-mail, once you receive the tags stick them to the box that contains your console and await collection. It usually takes up to 5-7 weeks before your u get your console back.
Jul 26, 2011 | Video Game Consoles & Games
My xbox 360 had one red light flashing and my av jacks did not work so i put the old casing back on and now has 3 red lights
The red flashing lights are a sign of a fault with your console.
firstly if you get the 3 red lights then microsoft reapair your console for free so long as you purchased it no more than 3 years before you send it back for repair. The 3 red lights are a sign of overheating
the 360 motherboard is able to flex a little, when the 360 was turned off and cooled down these solder balls solidified again, however they solidified in the wrong place or in two halfs etc. and so the 360 shows the 3 red lights to indicate this fault.
click here to download repair guide
Dec 15, 2010 | Microsoft Xbox 360 Console
I have three red lights flashing
Well you're either in luck, or in deep trouble. If you have bought your xbox 360 within 3 years, you have a special warranty provided by Microsoft. Call them or go to their support site, and list the problem as having three red light flashing. IMPORTANT it has to have 3 red flashing lights, with only the top right not flashing to have the warranty. They will send instructions and a box, and you just have to wait
Nov 07, 2009 | Microsoft Xbox 360 Console
X Box 360
It might be Red ring of Death problem, You can either send your Xbox toMicrosoft and wait for 2-3 weeks till you get back your Xbox or you canfix the problem yourself with the help of a DIY fix guide.
Check out the post discussing about RROD problem here: http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/
Hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
Oct 17, 2008 | Microsoft Xbox 360 Console
Reds light's
you can't just remove the 2 x clamps, you need something to hold the heatsink down. Get yourself some m5 screws and washers and screw it down to hold the headsink, cpu and the board together.
Jul 27, 2008 | Microsoft Xbox 360 Console
X-box 360
hey i had that problem
i found there a new trick to get the xbox to work its only temp tho
heres the link
http://www.youtube.com/watch?v=avWs4-wD15w
if that doesnt work microsoft will fix it
hope this helps please rate me
regards grant
Nov 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
204 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
