Question about Uniden Radio Communications
How do i progam a channel - Uniden Radio Communications
  • Uniden Master
  • 17,173 Answers
What is the model?
Posted on May 20, 2013
Scan button says all channels locked out
You need to press one of the number buttons to 'open-up' or turn on a bank of channels to scan (IF you already have channels progammed in Bank #1, then press 1 while scanning and those channels in that bank will scan)
Nov 22, 2012 | Radio Communications
Preout section cannot ingage
If you are using a pre out to a sub woofer, you need to make sure that the sub has it's own power amp or it will not work. You also need to go into the user menu and tell the amp that you are using a powered sub. Otherwise it will not turn on the pre amp output
Jun 20, 2012 | Denon Avr1610 5.1-channel Home Theater...
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
30 channel 10 band radio scanner uniden 8c60xlt
Make sure you have fresh batteries,turn on the unit,press manual,enter the channel number,press manual,enter the frequency you want,press E enter,if you make a mistake, press CLR to erase. Get the frequency,s for your state at RadioFreq.com. ..hope this helps..
Mar 19, 2010 | Uniden BC60XLT Handheld Scanner
I can't progam the converter box whit the tv
Is the TV on channel 3 check the TV and see if channel 3 is deleted and re -add it and try again. Coverter boxes are channel 3 or even 4. without futher details on what your tryed please rate me accordenly.
Apr 22, 2009 | Televison & Video
DTA800B1 how or should I say why can I not see channels on the VCR when the converter is hooked up to it and the tv works just fine but will not set the channels on the vcr
instead of putting the converter box on ch4 ,put it on ch3 same as the vcr . set the converter box channel for the channel to be recorded, program the vcr to channel 3 for the channel to be recored. set the time and date on the vcr progam.tv does not need to be on for the program to be recored but the converter box needs to be on.
Aug 21, 2008 | RCA Televison & Video
GE 46GW945 46" Projection Color TV
Over the air channels 60 or above will all be gone soon. The space will be allocated to cell phones and such.
This may be what you are seeing.
Aug 10, 2008 | GE 46GW947 46" Rear Projection Television
TV problem
Might be as simple as you have the SAP or second audio progam turned on, go in to the sound menu of your set and see if it's set to S.A.P if so turn it to Stereo
May 15, 2008 | iLO 2600 Television
Samsung tv
Channel-programming is usually done in the TV's setup menu. Some universal remotes don't have the Menu or Setup key required to get into the TV's menu, so check the TV itself to see if there is a Menu or Setup button.
Once you get into the menu, look for an "Auto Program" or "Program Channels" setting.
Apr 06, 2008 | Televison & Video
Radio Communications Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
