Question about Dell Inspiron 8600 Notebook
Ethernet port not reading my modem for my dell inspiron 8600
Can't figure out how to get online when i plug my broadband modem directly into the ethernet port of my inspiron 8600 laptop!!!!!!
also, my laptop doesn't have any sound.
i don't know what the hell i'm doing but creating a HUGE headache for myself!
  • 68 Answers
Make sure that your tcp/ip networking is set to 'Obtain IP address automatically'.
Power modem first , then laptop. Make sure that you are using the right cable for connection between modem and comp.
Posted on Mar 12, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
I have a PS3 slim console and it is having some internet problems that I cannot figure out. I have a CAT-5 ethernet cable plugged directly into my modem which is directly connected to my PS3. Many times...
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
UDP 3659
UDP 3660
You can use to test if the ports are open.
Nov 07, 2010 | Sony PlayStation 3 Slim Black Console
Im having ethernet problems with my inspiron E1505 dell laptop. after a reboot the computer no longer recognizes ethernet plugged into it. the cable has been tested and works fine. the drivers (Conexant...
Your ethernet card is not working and it seems to be damaged so if your laptop in under warranty so replace it free from the service center. Otherwise they will take charges for this replacement.
Ashish Kumar
Feb 02, 2010 | Dell Inspiron E1505 Notebook
Internal modem is not working
Are you sure it's a modem port and not a ethernet port. They look very similar and people confuse them easily. The ethernet port is slightly larger though. So we can verify we're talking about the correct thing, are you using dialup to connect to the internet? or are you connecting to a broadband router or dsl modem?
in either case you should be able to get drivers on dell's website and copy them over to your laptop.
Oct 07, 2009 | Dell Inspiron 2200 Notebook
Missingg ethernet card driver for Inspiron 8600. Information on system components is Intergrated 10/100 Network Card and Modem. I have no driver file on disks
Go to the dell site and check the support options for your computer. There should be a driver download section, and in there you shoud find the correct network driver. In theory, it's as simple as that to sort integrated component driver issues.
Sep 30, 2009 | Dell Inspiron 8600 Notebook
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Inspiron E1505 - Bad ethernet connection
right clik onmy network places chekc your lan card is enable?
if not enable it.
Nov 01, 2008 | Dell Inspiron E1505 Notebook
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
Wont work can not conect to the internet with it
Hi wolf,
Did you plug the modem into the internet port? The modem give the router its internet, the router distributes the internet from there.
Here is the online documentation of the router if it helps any:
Oct 17, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Dell Inspiron 8600 Notebook Logo
432 people viewed this question
Alun Cox
