Question about RTO Oar Sockets
Year model by serial number 06310270 1996 bass tracker boat 40 hp 4 stroke mercury/marine moter model #1996 40elpto
Need photo of engine. or a break down, of the engine. please help. ty
2 Suggested Answers
  • 115 Answers
SOURCE: 2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
Posted on Sep 03, 2009
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
https://dmna.ny.gov/nynm/manuals/Mercury_150_FourStroke_Manual.pdf
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine
https://www.mercurymarine.com/en/au/service-and-support/owners-resources/ The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/150-hp/ The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine
https://www.mercurymarine.com/en/ca/landing/outboard-care/ Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
Mariner 8 hp outboard serial number 0G156538 -- what year is this engine?
Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly
Hey Peter, try these guys.
https://www.marineengine.com/
Jul 03, 2017 | HP Boating
1998 1150412UD Mercury Outboard - is it 2 or 4 stroke
If it has an oil compartment, it has to be a two stroke. There is a rough and ready way to check. A four stroke engine has a compression stroke on every four strokes, whereas a two stroke has compression stroke on EVERY upward stroke of the piston. Remove the spark plugs, and turn the engine until you see the piston. Put your finger over the plug hole and turn the engine one revolution. Do you get compression? Keep turning, do you get suction and then compression again. If so it is a two stroke.
you can also follow the pipes from the oil tank and see where they go to? Yours should have a pipe from the pump to the carburetor inlet manifold.
On a new boat though, my advice for you is to take the boat and engine to a marine engineer for a service. The cost is minimal and you will get everything set up for the season, especially the carbs. You can ask lots of questions. The cost is about $150 and is well worth the piece of mind that you are not going to break down.
The critical bit you have missed from your post is the HP. If you Google
Mercury HP Serials
and you will end up at a site with engine details. Then google the same, but manual instead of serials. If you know the year of the boat, add that before 'Mercury'.
Use Evinrude XD50 two stroke oil. It is expensive but the best in clean running, non fouling and lack of acrid fumes. One $48 jug will last a season and a bit if you go out twice a week as I do. My boat goes to the marina on Wednesday :>)
Google
May 29, 2017 | Mercury Boating
I have a 20 hp mercury outboard serial#06082001.I want to know what year it is and if it's 2 or 4 stroke
If you drop the first zero it would put it at 1981.
http://www.themarinedoctor.com/msn.pdf
this site gives a different answer, as 1980- 81, so close. It SUGGESTS it is a 4 stroke engine.
http://www.boats.net/parts/search/Merc2/Mercury/25%20%282%20CYL.%29%282-STROKE%29%28International%29/parts.html
It is likely a 4 stroke, but I won't give you a definitive answer, due to the damage it can cause with a guess!
A four stroke running with two stroke oil will just smoke, but a two stroke with no oil will seize and leave you stranded on the water with a seized engine!
A four stroke engine has valves operated by push rods or a pulley and a chain, a two stroke just has a head. Take a look at the engine and it should be obvious.
For your first service, I would suggest you go to a marine engineer. Ask all the questions, and get the right answers. When I had my 1986 Evinrude serviced, i typed a list of questions and left the list with him. i asked him when I picked up the boat and wrote the answers down. The first one was 'petrol to oil ratio and which is the best oil'. A basic service will cost you a hundred bucks and you will have some comfort that you are unlikely to break down, 6 miles offshore with only a paddle :)
https://www.google.ca/search?q=20+hp+mercury+outboard+serial%2306082001&ie=utf-8&oe=utf-8&gws_rd=cr&ei=uwm-WKjHK6SUjwSApJLQBw#q=mercury+outboard+serial+number+lookup&*
Mar 07, 2017 | Mercury Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
Gidday,i am trying to find out the year of my 50 h power mercury blue band . The serial number I have is 8016593 and I am looking for both the inner and outer wiring harnesses
50 hp is a 4 cylinder powerhead.. blue band denotes 80s model engines.. my dads was a red band 69 model.. the red band stopped in the late 70s like 79 .. the wire harnesses are almost identical from 40 hp on up to about 80 or higher, just a heavier set of starting cables.. may need to check into used equipment.. might find something easier there.. check mwith a mercury dealer near you also..
Nov 19, 2014 | Light Outboard Motor Boat Bass Fishing...
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
RTO Oar Sockets Logo
37 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
