Question about Craftsman Garden
Lawn mower steering
Hi. My mom has a Craftsman Riding Mower. The rod that comes from the steering wheel to a ball type thing on the front axle won't stay on. Almost like the hole in the rod is wore to the point it is too large to hold "ball." What can I do to fix this? Right now we are zip-tying the rod to the axle, which only lasts a little while. Thank you!!!!
    Sergeant:
  • Craftsman Expert
  • 369 Answers
Order new piece. Parts are pretty cheap on ebay or amazon.
Posted on Jul 07, 2014
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 6 Answers
SOURCE: Craftsman riding lawn mower wheel toe needs adjustment.
put it in reverse ton the wheel to the right and hit the wall again....or ir you were backing up when u hit the wall runn into foward
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Part required for Craftsman Ride on Mower 38" model 917.259040
go to parts tree.com.put in your model#.they will probably have what you need.hope this helps
Posted on Jun 17, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Posted on Aug 23, 2010
Adjusting tow in on craftsman pro riding lawn mower
You can try streightening the steering link rod. or just buy a new one. also make sure the holes on the axle brackets arent wallard out.
Jun 30, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower front tires are hard to turn cause they want to point in different directions and not straight. what could cause this
1) The tie rod between the front wheels is bent or the adjuster nut has come loose.
2) The plastic wheel bearings have gone to sh*t on either or both sides
3) The steering knuckles were never greased and their bushings are shot to sh*t.
4) The front tires have come off the rims
5) The front axle beam has been bent
Find a small engine repair shop in the yellow pages and have a person with know how put his eyes and hands on it, you will know within a few minutes what is wrong.
Sep 22, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Two front wheels misaligned, one is straight and the other points outward
To give you a professional soultion I really need a complete model number.
Here is what happens when steering becomes a problem on ANY brand of riding mower.
1. Tie rods get bent
2. Wheel spindle pivots get bent on one side.
3. Pivot bearings or bushings get worn
4. Linkages from the steering wheel to the tie rod pivot connection get bent.
On the basic bottom of the line Craftsman riding mowers the tie rods are fixed and not adjustable. However if you look for a mirror image left to right of the tie rods often you will note that one of them is bent in or out... or is shorter than the other one. There are after market tie rods that are adjustable. This is over 40 years of experience talking here.
THe best way to do an inspection of steering is to place the mower on tripods so that the fram is being supported and not the steering components and then set the steering wheel to the straight position and inpsect ALL of the steering and suspension components for the front end.
Without your model number this is quite generic. With a model number I can show you a parts diagram by item number of what to check.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Was mowing the lawn when all of the sudden i heard a pop and the steering went on the mower. The steering wheel just spins and the rod underneath the engine is just hanging
There is probably a ball joint connection that broke, or something could have just came loose. Not a hard repair, if you are not mechanically inclined, any mower shop can fix it, or if you have a neighbor that works on cars etc can fix it easily.
Apr 24, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman lawn mower
Hi judycdenn
You can get replacement wheels from most decent hardware stores, either with ball race bearings, or just plain old plastic bushes. they don't cost much, I would take in my old wheel to get one that fits.
But before you go buying spares for the mower... you should read this
regards
robotek
Apr 28, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
112 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
