Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
No spark to spark plug what is wrong - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
    New Friend:
  • 171 Answers
Ignition coil . they had problems with them.
Posted on Jun 23, 2013
Hey guys, I have 04 Mazda MPV where #4 coil keeps going bad. Any suggestions why?
A coil goes bad when it's under stress. What causes stress? Wrong spark plug, wrong spark plug gap, improper air/fuel mixture that causing misfires. Any time a spark plug misfires, it can wreck an IGN coil. The spark has to go SOMEWHERE
Jan 30, 2018 | Mazda Cars & Trucks
I changed spark plugs on my 01 jeep grand cherokee it was running but turned off on me now it wont start anymore.
which engine?
2001 WJ , jeep.
wrong spark plugs!
gapped wrong!
wrong wire order?
do tell engine you have there.
do tell park plug brand and numbers.
do tell if engine has coil packs, how many, and how you wired them back..
now answering for USA cars, (not exports. or those jeeps made in Europe. )
the 4.0L engine with the 3 coil rack pack? with 6 spark wire sets?
the 4.7liter has 6 coil packs coil over plug COPS.
that can not be wired wrong but could be unplugged in primary side.
my guess, wrong parts, wrong gap
or not reconnected right.
if spark is lost, scan the PCM cranking, look for DTCs/
Dec 24, 2015 | Jeep Cars & Trucks
Whats behind spark plugs on a 4.3 liters gmc pick up
Directly behind your sparkplugs are the pistons. If the sparkplug is damaged, it was either the wrong plug and was too long (the piston was hitting the plug), or there is foreign debris in the engine chamber!
Apr 28, 2012 | Cars & Trucks
I had someone replace something on my GTI and I think they put the spark plugs in the wrong order
Hiya they cant get the spark plugs in the wrong order and the coils that go on top are interchangeable aswell there really is no way of getting them mixed up, i suspect you may have a fault on the car , rather than someone fitting spark plugs round the wrong way
hope this helps Chris
Jul 28, 2011 | 2006 Volkswagen Golf
I just changed the rotor cap, distributor cap and wires and plugs and wires and its putting and wont let me get past third gear.
IF VECHICLE RUNNING ROUGH OR MISFIRING YOU COULD HAVE WRONG SPARK PLUG GAP.SHOULD BE 0.040 - 0.043 IF PLUG GAP CORRECT YOU HAVE WRONG PLUG WIRES OR WRONG TYPE OF SPARK PLUGS.
Mar 07, 2011 | 1992 Isuzu Rodeo
Misfiring after replacement of spark plugs and wires
If it wasn't misfiring before. Make sure you have the proper gap on the spark plugs. Make sure you have the wires connected in the correct order. If you have the old wires, you may want to end up trying those one at a time to make sure you don't have a defect wire either.
Thank you,
Lee
Mar 04, 2011 | 1994 Ford Escort
My car won't stay cranked after Iv'e changed my spark plugs. Did i knock anything loose?
REPLACE SPARK PLUG CABLES.IF YOU REPLACE SPARK PLUGS GOOD THING TO REPLACE PLUGS CABLE ALSO.
Nov 28, 2010 | 2006 Kia Optima
Changed my spark plugs yester day think i spaced thm wrong car ns
EITHER SPARK PLUG GAP INCORRECT GAP IT SHOULD BE 0.028 - 0.032 OR USING WRONG TYPE SPARK PLUGS.YOU HAVE TO USE WHAT THE FACTORY CALL FOR.
May 11, 2010 | 2004 Kia Optima
My car wont start after i changed spark plugs and wires.
did u mix the plug leads up when u replaced them wrong firing order 1342
Apr 02, 2010 | 1994 Honda Civic
Rewired ford taurus spark plugs and when turns on it jumps what could i have done wrong?
If you replaced the distributor cap then there is a high possibility that you put the wires in the wrong firing order on cap.
If all you did was replaced the plugs, then I would pull each one out and recheck the Gap sizes with a feeler gauge. Also check to see if the spark/coil plug wires are touching metal or each other, which can cause the spark to arc out of the wire and never get to the spark plug. If I suspect an arc and do not see a physical problem, I wait until nighttime and look under the hood while engine is running...they stick out like a sore thumb. Also make sure that you did not put the wrong plugwire to the wrong spark plug.
When you change your plugs, you should also replace wires, cap and rotor.
Oct 17, 2009 | 2001 Ford Taurus
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
78 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
