I have a new Viera WT50A and upgraded to Foxtel HD
We had the old IQ Foxtel box and the picture quality was poor (given the poorer quality signal from the SCART cable/Foxtel SD signal). We upgraded and the picture was perfect most of the time. We are now noticing notable blur (a slighted outline around the head, for instance) in some sport but also in many other programmes. This seems to mostly occur when playing back a recorded programme on the IQ HD box. We use HDMI cabling and have the Foxtel HD channels. Is this because the recording is not the full HD or can you provide some other solution - or comments from others with this problem. Thanks
2 Suggested Answers
  • 11800 Answers
SOURCE: Just bought a new panasonic
The SCART connector uses by default the RGB colors outputs, your tv might not support it. The full proof method to connect the box to the tv is to use the 3 RCA connectors : Yellow, Red and White. The image quality will be practically the same if you use a good cable.
Posted on Nov 19, 2010
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Poor picture quality
First of all do you have a HD signal?
these sets are made for HD and most look good when you set the HD box to 1080i , the cheaper sets do not look good with a non HD signal.
check all inputs, dvd, HD air, and component and post which are bad to get more help
Jul 26, 2009 | Televison & Video
Can't get clear picture on my 50" Samsung DLP
Most of the Analog viewing will be much poorer compared to HD. Since it it a digital product, it is designed to be used with a digital signal. You will get signal degradation if it has to take the analog and convert it to digital to be viewed and there is really nothing that can be done to compensate for it.
Hope this helps,
Jul 04, 2009 | Samsung DLP HL-P5663W 56" TV
Panasonic Viera link and Foxtel IQ
It is very likely that cross talk does corrupt the link but for Panasonic to "blame" anyone else is not very professional. Anyway, if it worked for 6 months perhaps disconnecting the Foxtel IQ and reestablishing the Viera link with the Panasonic devices then reconnecting the Foxtel IQ for another 6 months of happy viewing. This is not a permanent solution but the alternative doesn't seem to be an option.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Hi. im a french guy so you could not understand really what i want to ask.Yesterday i bough a Sanyo HDTV Model No : DP37647 and the image is really ugly ( huge pixels ) compared to my previous old tv. i...
you will get poorer picture quality if you aren't watching on an hd signal . the pixels shouldn't be extremely big, but they will look off compared to a normal tv.
Oct 20, 2008 | Televison & Video
Yes, you must get a HD box. Digital is not HD quality. You will use the hd inputs on the jack panel that are green = Y
blue = Pb
red = Pr
Audio will be Red & White ( L+R )
Feb 12, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Not clear picture
If this is an HD set and you are using a SD signal I have seen many disappointed people because the upgrade that takes place in the digital video circuit is far from perfect. It will not look like it did at the store without HD!
Apr 21, 2007 | Samsung TXN2798HF 27" TV
Televison & Video Logo
Top Televison & Video Experts
