Question about Sewing Machines
Where can i get
I turned on accidently my machine in the 220w and the machine is to be using in 110w. I understood that the pane is burned.i need to get a new one
  • Sewing Machines Master
  • 7,365 Answers
You'll have to contact a brother dealer and ask them if they can
get one.
Posted on Apr 24, 2013
My pfaff sewing machine is not flush with working table. how do I fix problem?
Put something under the machine's feet to raise it? Not sure your question is understood.
Nov 03, 2016 | PfaFF Sewing Machines
How do I replace or clean the LCD screen cover on my XL-100? I accidently left the light on and scorched the screen. Everything else works fine. Thanks
Unfortunately, cleaning will not help--your screen has the images burned in. The entire assembly is available from Sewing Parts Online; however, it costs $550, and you really don't need it--it includes ALL the parts, and all you need is the screen itself. The parts number is #386988, and if I were you I would give them a call and ask if they can order just the screen for you, and if so, how much it would cost.
At the same time, you might want to order the service manual from them--if you're going to attempt this yourself, you should really have it.
Mar 01, 2015 | Singer Quantum XL-1000 Computerized Sewing...
My machine does not feed fabric what is the problem
Have you accidently hit the feed dog? Just a thought.
Jan 22, 2015 | Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
Janome 11000se grey screen
Do you know where the manual dimmer switch is located for the screen. Maybe this was accidently turned dimmer. I've seen this happen way to many times to mention....
Machine Tech
Oct 19, 2013 | Sewing Machines
The software for my Feiyue EM3000 embroidery machine does not work on my Windows 7 laptop, where can I get software to run my machine?
One may go through the windows XP for sure.
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
http://mhelpdesk.com/field-service-management-software/
Oct 12, 2013 | Sewing Machines
How to thread singer electronic machine (model 2517) I put the cone thread on top of machine but can't secure it to continue on with threading the machine
are you using a large cone of thread such as would be used on an overlocker? If so, yes you will have problems on a domestic sewing machine. Either run some thread off to fill a bobbin and then use this on the top of the machine. Or buy thread in a thousand metre spool and use this, its better quality thread and certainly easier to place on the machine 's spool holder. If you really want to use the bulk cone, then you probably need to buy one of these to make it possible.tally_girl_72.jpg
I hope I've understood your problem. If you need threading diagrams for your Singer then go to their website http://www.singerco.com/accessories/instruction-manuals and download your manual, most are there.
Jun 03, 2011 | Singer Electronic Sewing Machine
I would like to know if you have double pane window replacement
wrong site
fixya site doesn't do parts , just technical replies
Oct 16, 2017 | Husqvarna Viking 1
Our Viking Windows (early 1980 vintage) have lost their seal so they "sweat" between panes. We'd like to remove and replace the panes but leave the window frames in place. Can you describe the...
UMMMMMMM,
Somehow you have ended up asking this question in a forum for sewing machine repairs, so best if you re-post in a different forum if you want more sensible replies !!
Probably happened as Viking is also a brand of sew machine....!?!?
May 26, 2008 | Husqvarna Viking 1
Software Problem!! Design task pane not popping up!!!!
I had this happen to me as well, I'm not sure if I remember what I did to correct it but I think I left the frame in place and closed up the futura program and turned off my machine. waited a minute and reopened everything in the proper sequence. then reopened the design I was working on.
Apr 05, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
