Question about Dupli-Color Scratch Fix 2in1 Touch-Up Paint White Color Code 045 1/2
Jan 2010 bci bus model number jxk6127br1 - Dupli-Color Scratch Fix 2in1 Touch-Up Paint White Color Code 045 1/2
Winchester model 74 serial # 11901, what year was that gun made
My Internet at work doesn't like 'weapons'. These links will help you find the date.
Model 74 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
Winchester Model 74 .22 sr dating question ' The Firearms Forum
www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
Winchester Model 74 Value And Date ' Gun Values Board
www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
Jan 22, 2016 | Winchester Optics
On land rover discovery handbook, it says need group size 24 battery, why in all battery stores say I need group size 34?
The size numbers you are referring to- 24 and 34, refer to the BCI group number of the battery. These numbers define the physical dimensions of the battery case- that's it!
It has nothing to do with the CCA [cold cranking amps rating] or AH [amps per hour rating], or the battery life.
BCI stands for Battery Council International; it is a trade association of manufacturers of original equipment (OEM) and after-market auto batteries. This association is responsible for setting the standards and testing dimension and sizes of lead acid batteries.
So, to sum it all up, the BCI 24 battery has the following dimensions: its Length 10.3" (260mm); Its Width is 6.8" (175mm); and its Height 8.9" (225mm)
The BCI 34 battery has the following dimensions: Its Length is 10.3" (260mm); Its Width is 6.8" (175mm); and its height is 7.9" (200mm)
Both batteries have the positive polarity on the left hand side and are located on the top of the battery; they are for automotive use and are SAE (Society of Automotive Engineers) approved standards.
The difference between the two batteries are in their dimensional height; the BCI 24 is 8.9'' whereas the BCI 34 height is shorter at 7.9" by 1".
As long as the battery tray and the battery hold down clamps can secure the BCI 34 in place, you should have no problems.
HOWEVER, should you decide to buy the BCI 34, make sure the CCA rating is the same or more than the BCI 24; that's where it counts the most in cold weather. And of course, the reserve Capacity rating (RC).
Never compromise the aforementioned by going with lower ratings when replacing a battery to save a few bucks, because it will cost you more money in the long run when having to call for AAA services or replacing the battery again because of its short life due to energy demands that automobiles of today command as a result of all the electronic components that are used during the operation of the vehicle or the paralytic draw (slow power drain of the ECM and its components) when not in use.
Feb 20, 2015 | 2004 Land Rover Discovery
Will a canon printer i560 take PGI-220 , CLI-221 ink replacements. I purchased this at Costco. On the side of the box there are a number of numbers, one of them is MP560. Will this work?? Thanks ...
Hi Wayne. The i560 and MP560 are different beasts.
According the Canon, the i560 takes 1x BCI-3eBK, 1x BCI-6M, 1x BCI-6C & 1x BCI-6Y, and the MP560 takes 1x PGI-520BK, 1x CLI521BK, 1x CLI-521M, 1x CLI-521C & 1x CLI-521Y
Although the BCI-3eBK and the PGI-520BK look similar, they are in fact different.
Also the 3 colour carts look the same but are again different, the BCI carts all have microchips in them and the optical sensor in the bottom is also slightly different.
Searching the Canon supplies section, I cannot find either PGI-220 or CLI-221.
Apr 29, 2011 | Canon Office Equipment & Supplies
What is the ink cartridge numbers for the MP730?
Here are the codes for your cartridges: BCI-3eBk (Black), BCI-3eY (Yellow), BCI-3eC (Cyan), BCI-3eM (Magenta)
Dec 28, 2010 | Canon SmartBase MP730 All-In-One InkJet...
I think I put in a wrong colored toner cartridge. Pages printing in wrong colors. Can't find a list of the cartridges I should be using.
The make and type of cartridge is generally given in the users handbook/manual provided with the printer. If you do not have that ,you can log on to Canon web site and then go to support. Select your printer model and you can find the the specification of cartridge to be used with your printer. The list of the cartridges is given below: BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank You can also go the this link and download the manual if you do not have the same http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#Overview
Nov 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Will PGI-5BK and BCI-3E ink tanks fit in the MX700?
Ink Tanks:
PGI-5BK, CLI-8C/CLI-8M/CLI-8Y
According to the canon australia website these are the inks for the MX700
Feb 20, 2008 | Canon MX700 Office All-In-One InkJet...
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be reset.it may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
Solve GSM CMS Errors......
I'm using also smslib and nokia 6020 phone for sending and receiving SMS, but i've some trouble with reading messages, would you please tell me the configuration for the modem, i used this one :
ModemGateway gateway = new ModemGateway("modem.com4", "COM4", 4800, "Nokia", "Nokia 6020", srv.getLogger());
Oct 01, 2007 | Microsoft Office Outlook 2003 for PC
Dupli-Color Scratch Fix 2in1 Touch-Up Paint White Color Code 045 1/2 Logo
32 people viewed this question
Top Dupli-Color Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dupli-Color Air Tool and Compressor Expert? Answer questions, earn points and help others
