I have a Gateway Laptop Model ML3109 and have a display problem.Laptop was on and screensaver was working when I went to use the computer one half of the display is gone on my screen, the other half is fine....Help
I have a getway computer and believe the inverter went out on it. I am trying t order one but do not know my model number or what info I need to order one
The laptop model is printered on a label on the bottom of the laptop.
The model number could also be displayed in the BIOS configuration.
Jun 17, 2011 | Gateway Computers & Internet
I have a Gateway Laptop and a ViewSonic monitor and relocated them into my office yesterday. The ViewSonic was working fine. When I booted everything back up the Viewsonic turns on, flashes my...
It means that there is no video signal from your video card. 1. Check the video cables 2. Try connecting your internal video card if you have one or change the card with new one.
Feb 28, 2011 | ViewSonic VX1935wm LCD Monitor
My laptop screen will go black. If I tap on the mouse or mousepad, it will come back on. Sometimes it stays on and sometimes on and off for awhile
I would check the Power features under "Display Properties", "Screensaver" tab, then monitor "Power" located at the bottom of the "Screensaver" tab. Check the settings located there and see if that helps.
Jan 02, 2010 | Gateway M320 XL Notebook
I want a CD-Rom for gateway model Ml3109
The best way to obtain the same drive is to contact the manufacturer. They will have a parts department in which you can order the CD-Rom drive :o)
Aug 13, 2009 | Computers & Internet
My screen only displays after 4 /5 hrs
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Jul 23, 2009 | Computers & Internet
Vista Remote logoff problem
the computer most likely goes into screensaver and it is set to logout / lock the computer everytime the screensaver is opened.
right click on your desktop select personalize, look in the screensaver settings. Take the Check out from the box that says, On resume display login screen.
now the computer wont sign you out every time the screensaver comes on.
Jun 16, 2009 | Microsoft Remote Desktop (V3H011652)
Screensaver want work
Go to:
Start >> Control Panel >> Display >> Select the tab ...Screensaver
Modify the settings of your screensaver there and also (enable - disable)
Oct 27, 2008 | Gateway Computers & Internet
"Local Access Only"
You need to look on the back of your router and find the small reset button. Push it and everything should reconfigure. If not Go into your device manager and see if you can find something called a NIC card or Network Interface Card, or something called an Ethernet card, if those are not listed, it means your driver has been deleted somehow. You can go to the manufacturers website and download a new driver.
Sep 22, 2008 | Linksys WRT55AG Router
I would first try a system restore back to the time it worked.
If that doesn't work, scan for viruses and other malware.
Aug 27, 2008 | Gateway GT4022 PC Desktop
Go to START, PROGRAMS, ACCESSORIES, ENTERTAINMENT, Volume control. With the volume control open, see if the volume is muted (Checkbox marked mute at bottom of Master volume) If it is checked, uncheck it, and you should have sound.
May 16, 2008 | Computers & Internet
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
