Question about JVC Televison & Video
My tv screen cuts off the images so the words are not all showing
HOW DO I MAKE THE ASPECT OR SOMETHING CHANGE TO SHOW ALL THE WRITING
  • JVC Master
  • 3,459 Answers
What you describe is known as a convergence board problem. Its a fairly common problem. You can read more about it herein this Fixya Tip.
http://www.fixya.com/support/r4581251-convergence_failure_test
Posted on Apr 26, 2013
  • 1153 Answers
SOURCE: picture flahes on and off when watching show
do self test diagnosis first
Posted on Dec 16, 2007
  • 4234 Answers
SOURCE: Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Posted on Dec 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: TV is showing blue and green mixed double images .
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 06, 2010
SOURCE: How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Posted on Sep 22, 2009
Ecollier2012
  • 3459 Answers
SOURCE: I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
Tv is not showing complete picture....some things are cut off
Change the aspect ratio.this can usually be done via the remote or through the tv menu.normal view for most wide screens is wide 16:9 but if you have zoom or crop black bars then you may lose parts of playback.
Feb 19, 2015 | Vizio L37 Television
Change the image size on my TV screen? I want it to fill the screen
It will be in the menu under something like display or video settings. From there it will be a sub menu like aspect ratio. Your remote may have an aspect ration button on it as well. Some even list it as wide display or image
Feb 15, 2015 | Westinghouse Electric W1603 15.6 in. LCD...
How do I stop the words from being cutoff on the tv screen?
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
Jan 04, 2015 | Panasonic Viera TC-P50S1
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
Picture size on panasonic txl32 tv
Change the aspect ratio on the remote. If this does not fix, change the aspect ratio on your cable or sat box.
Apr 10, 2012 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
NEED TO ADJUST THE VERTICAL SIZE OF A PANASONIC TV
Has the image been "zoomed" into?  This is usually the result of a image that has been adjusted to fill the screen.  This is not the same as adjusting the aspect ratio as that would still show the entire image even if distorted.  When the image is cropped or is missing information, a zoom feature is usually the culprit.
If this isn't the problem, you maybe able to adjust the TV's horizontal/vertical placement through the TV's onscreen menu but only if it provides that option.  Do you see other channels that appear to fit properly?  I have seen certain channels not fit correctly while others do and this is due to the signal, not your TV.
Mar 25, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
