Question about Refrigerators
Frigidaire model# 240508004a leaking in the back by the water line
5 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: Kenmore side by side ref
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 12, 2011
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
  • 4736 Answers
SOURCE: Water leaking out of frigidaire
First, have you drained the tank recently. If not, the warning light or auto shutoff failed and the tank may be overflowing. Worse case scenario is the that the tank is dirty and is not allowing the coils to cool and the dripping water you see is from the cooling coils. Since the tank is not removable, it's very difficult, at best to clean the tank.
If you drain the tank and before reinserting the drain plug, try to get about 1/2 teaspoon of bleach in the drain hole. followed by 2 cups of water. Of course you'll have to use a funnel of sort to do this. Reinstall the drain plug and move the unit around so the water and bleach will slosh around. Then run the unit until the bucket is near full again and drain it thoroughly. Look at the color of water draining out, for an indication that there is dirty water. That will be a good indication, that some cleaning of the tank has taken place.
Hope this helped you and thanks for choosing FixYa.
Posted on Jul 29, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire, model #FRT18B4AWA Leaking water, drip pan is full
    Has the unit gone into a defrost cycle recently?
    Posted on Aug 03, 2012
    Frigidaire washer model LAFW70000LWO leaking from bottom of washer
    would suggest cleaning out the coin or filter trap to see if debris has clogged the drain lines. This may or may not be specifically for your model, however these are generics instructions that I found.
    To check for a restriction in the drain line you will need to follow the steps below:
    1. Unplug the washer
    2. Pull the washer out to tilt it back so you can
    reach the screws below the front panel and
    remove it. (You will need something to catch
    the water once the hose is removed from
    the bottom of washer)
    3. Loosen the bolt with the sliver clamp on the
    bottom of the washer. The water will begin to
    come out while your loosening the clamp. (Do
    not remove any GREEN clamps)
    4. Once the water is out, you can stick your hand
    inside the hose to clean it out.
    If any proves to be ineffective contact a professional so they can properly and accurately diagnose the unit for repairs. Unit could possibly have a damaged/cracked tub, a leak in the drain lines, or the water valve.
    Dec 05, 2012 | Frigidaire Washing Machines
    Water leaking from under Frigidaire fridge
    Hello - There are many reason for this issue to occur, for example the refrigerator could have a crack in the defrost pan, a defrost drain line blockage, a leak from the water supply line for the dispenser or ice maker, but most cases water leaking inside and draining through the refrigerator cabinet. Try confirming that the vales are tightened. If the connection is still leaking, turn of the water supply line to the water valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. If these suggestions prove to be ineffective contact a professional to move forward accurately.
    Oct 02, 2012 | Frigidaire Refrigerators
    No water to the ice maker
    filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
    Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
    I have water leaking out the back of the freezer side of my side
    Pull the fridge away from the wall and check where the water line enters the fridge for the ice maker. If there is a fitting there, make sure that it is tight or the clamp is secure. If it looks cracked or split in any way, remove it and replace it with new hose.
    Hope this helps,
    Jeff
    Jul 08, 2009 | Frigidaire GLRS264ZA Side by Side...
    Just replaced freezer fan a couple days ago. Now water leaking into top shelf of fridge. Could drain be clogged ? Frigidaire model FRT8S6ESBG.
    Frozen drain
    Ice maker water line and wiring
    harness openings not sealed.
    Seal water line and wiring harness
    openings.
    Drain trough not properly formed.
    Ensure drain trough is at 90° angle to
    back of freezer and that lip is up on front
    and ends.
    Divider (foam block) frozen.
    Replace divider. Check drain trough.
    Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
    http://servicepartstec.blogspot.com/
    Apr 04, 2009 | Frigidaire FRT8S6ESB Stainless Steel Top...
    Frigidaire frig ice maker line leak
    Could you put a small circular hose clamp on the hose line?
    Apr 23, 2017 | Refrigerators
    Frigidaire Side by side Leaking water from Behind the dispensor
    You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
    Apr 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
    You have a bad diode on the water valve connection frigidaire has a kit for this fix..
    5303918287, 5304418384 DIODE KIT frigidaire
    Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
    Refrigerators Logo
    496 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
