Question about VeriFone PINPad 1000SE Network Terminal
Veriphone Pin Pad port changes under Win 7 Pro/64
Thanks for reading. I have 4 Veriphone Pin Pads installed on computers for our POS system. However, the one installed on Win 7 Pro (64 Bit) keeps changing its Com port. More properly, the default Com 9 is not released by Windows when it is shut down, and a subsequent boot will see it reassign to the next Com port (10). We have two other Win 7 computers that have no such problems. These are Win 7 Home Premium 64 bit machines. In all other respects, the Pin Pad functions properly. I use the Verifone ComReset utility to clear Com 9, go into the device manager and reset it to Com 9, and all is well. Until the next restart. I've also set up a batch file to clear Com 9 and it is run on startup from Startup. However, that happens after the driver is loaded and I still have it assigned to Com 10. I would appreciate any ideas on how to make this work. Thanks, Andy I would appreciate any help or ideas.
2 Suggested Answers
Blackberry_U
  • 223 Answers
SOURCE: I need a Vista driver - the XP driver won't install under Vista
Check for the driver on the make and model's web site, not the windows...you should find what you are looking for.
Posted on Jun 01, 2009
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
Qc848enu-Compatibility issue in Win 7 64 bit
Hello
It depend on the CPU if it is 32bit or 64bit. Windows 7 64 supports 32 bit software and 64 bit I suggest re-installing the software. It depend on the software if they have 64bit and 32bit you should install the version your PC is. Sometime 32 and 64 bit are embedded in software.
Feb 05, 2014 | Logitech qc848enu.exe
I have Sony DCR-TRV285E Digital-8 Digital Camcorder Driver for win.xp but i have the program for win.7
The USB streaming driver for the Camcorder is not available for Windows 7 OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
  1. Connect an i.LINK cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
i.LINK Cable.
i.LINK port.
  1. Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  1. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  2. Cue the camcorder tape to the beginning of the video footage.
  3. Turn on the computer.
  4. Start the video capture software on the computer.
  5. Begin playing the recorded video in the camcorder.
  6. Begin importing the video with the capture software.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Jan 16, 2012 | Sony DCR-TRV285E Digital-8 Digital...
Can not (re)install HP Solution Center in windows 7 (photosmart c6280)
check leads and connection points
once connected windows 7 should automatically detect your printer search for and install the drivers
click start control panel devices and printers if you see your printer right click on it
you might have to set it as your default printer
click start right click on computer device manager scrollto ports com & lpt
if you see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Dec 12, 2011 | HP Photosmart C6280 Printer
Can't install textbridge pro 11 on my pc with windows 7 64 bit. Can you help?
Apparently this is not compatible with win 7. Apparently their is something called xp mode in win 7 which may allow you to install and run it
Mar 13, 2011 | ScanSoft TextBridge Pro 11 for PC
I DON'T HAVE DRIVER OF EPSON STYLUS C59 FOR WINDOWS 7
1. Follow this web address : http://www.epson.com.ph/epson_philippines/support/eol_product.page?support_name=Epson_Stylus_C59#
2. Hit drivers button
3. Select the Operating system Vista if you have Win 7 - 32 bit or Vista 64 if you have Win 7 - 64 bit
( You can find out what win 7 version you have if you hit right click on My computer > Proprieties )
4. Download driver and install
5. do not worry, Vista drivers will work under Win 7
Feb 19, 2011 | Computers & Internet
How to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
VeriFone PINPad 1000SE Network Terminal Logo
82 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
