This is a generic computer, without a name. In my computer, it does not list the DVD/cd burner or the cd-rom when the computer starts up. It does show the drives in the boot up section. I believe this problem may have started when I installed the SP2 xp. I do not have the boot disc the computer is 9 yrs. old. It is a 450mz, athlon II with 128 ram, 20 gig hd. No brand name, white box. Everything else works. I have a lot of music files (2000) and pictures on the computer.
Hello my name is Tim, It sounds like you may need to reinstall the drivers and get your pc to locate the drives, you can usually get these drivers from the manfacturers website or from download.com for free, if you have the install disks for the dvd burner and cd rom you can use another pc to load them onto a usb drive and then transfer them to your pc that way. You can also go to controll panel, then device manager, and try to locate it there to see if it needs any drivers. I hope this heled you, please feel free to ask more questions and I will try to help.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
