HP laptop won't connect to home network when it previously did.
All diagnostic and configuration attempts lead me to believe that the network card is not functioning.
This occurred within the first year of my owning the computer, and the part was fixed by HP under warranty.  That was about a year ago or more.  All the symptoms are the same.
  • kozmikkurt May 11, 2010
    Is it a removeable network card? That would be easy enough to try swapping out. Also, it sounds as though you've probably already tried this, but if not, have you tried unplugging your modem and/ or router (if you are using one) for 10-15 seconds and re-plugging them in? For some reason, I have to do that every once in awhile in order to get a connection on one or more of my computers. I also had one computer that after years of no problems, suddenly would no longer connect - it turned out to be an update of the firewall software that was causing problems - once I got rid of that firewall software, it worked fine again.
I have a Packard bell laptop that will not connect to my wireless router. The laptop will context to my work wireless but not my home wireless. We have another two laptops in the house and both of them...
Network Key (WEP, WPA, WPA2 Encryption key) To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 17, 2012 | Computers & Internet
I have an hp compaq and it connects everywhere except my house?
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 14, 2012 | Compaq Presario Notebook
How can my friend connect to my network
May 25, 2012 | D-Link D Link Dir 601 Wireless N Home...
WILL NOT CONNECT TO LINSYS HOME ROUTER BUT WILL CONNECT TO WORK NETWORK
What do you mean it won't allow you to put in the home network passcode? When you click connect to your home network, does the password request come up for you to put it in? If not, you've got your settings wrong on the laptop
There are some configurations that allow you to put in the password and then are are some that allow you to use a pin. I bet you've got your connection in the laptop configured wrong.
Apr 28, 2012 | Dell Latitude E4310 Laptop
My HP Probook 4720S has a very wierd problem. The wireless card seems to be working properly, and the drivers are up to date.However it cannot detect the wi-fi in my office.Other laptops are connected so...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
If the other laptops are connecting to the wireless router, then look at the wireless card configuration in these laptops and apply the same settings to your HP Probook wireless card.
Sep 05, 2011 | HEWLETT-PACKARD HP ProBook 4720s 173...
I have a d-link router. i can connect to my
The wireless card is configured for your D-Link at home.
You need to configure your laptop's wireless card for the wireless settings at work too (ie the SSID and encryption etc.). Contact the network manager at your work for the wireless configuration so you can configure the wireless card with these settings.
It maybe possible to setup different profiles on the laptop's wireless card, one for home and one for work so you can just click on the correct profile depending on your home or work location.
Dec 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
Slow speed tests
Your HP G60 has an 802.11 b/g card. 802.11g has a maximum rated speed of 54 mbps, like the router. You never get the actual "rated" speed with wireless cards, this would occur only with maximum signal strength, no network protocol overhead, no security, etc. if you were to replace your current card in the Satellite with an 802.11 b/g card, you would get comparable results.
Jan 15, 2009 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Procurve 2626 installation
You'll need to obtain a comms lead - connects into the console port of the switch then into an RS232 port on your laptop. Then, you will be able to connect using hyper terminal and you can give the switch an IP address, username, etc. Even a hard-reset won't allow you to configure an IP address as by default it needs to be configured through the lead. Will they not talk without being configured? If you just hard reset them, they should just behave as unmanaged switches.
Aug 14, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Computers & Internet Logo
54 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
