Question about John Deere Starter Tractor Lx188 Kawasaki Engine
John deere lx188 ignition control module troubleshooting information for 17 hp v twin kawasaki engine
  • 100 Answers
SOURCE: have 1996 John Deere model LX188 - having problem
more then likely has faulty coil on one cylinder
Posted on Aug 14, 2010
suzukiracing
  • 200 Answers
SOURCE: i have a john deere 325 with a kawasaki 18 hp v
Try adjusting the deck height up a little or start a the carb.
Posted on Jul 19, 2010
  • 6468 Answers
SOURCE: i have no spark on my john deere hydro 175. fc420v kawasaki engine. replaced ignition trigger. whats next? thanks in advance for any help.
unplug the engine harness and then check for spark if you have spark its a bad safety switch
Posted on May 20, 2012
SOURCE: John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Posted on Aug 07, 2012
SOURCE: How do you remove mower blades on john deere lx188
Get yourself a rattle gun connect it to an air compressor with the right
size socket hold the gun on reverse it should remove the bolts.
Posted on Dec 10, 2012
17hp kawasaki v-twin loses power when under load
You may have a bad ignition coil. Your carb also may need to be taken apart and cleaned real good. You can find alot of good troubleshooting tips on google or youtube as well.
Feb 19, 2014 | John Deere Kawasaki K Series Air Cooled...
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
Apr 22, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
John Deere Starter Tractor Lx188 Kawasaki Engine Logo
292 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
