Question about Element Electronics Televison & Video
Faulty HDMI Port
HDMI ports on tv are faulty. When I connect xbox or computer through HDMI cord, the television will not recognize the device, or will take a long time (5-15 minutes) to link up to the device. The issue is not the cord, as I have tried changing the cords out, and the computer recognizes that it is connected to the tv.
    Top Expert:
  • Element Elec... Master
  • 74,383 Answers
A firmware update must solve this problem. It is a software bug. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Posted on Apr 24, 2013
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
SOURCE: My Philips 42PFL3603D/27 that does not connect to hdmi device.
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Posted on Mar 10, 2010
Testimonial: "While my problem did not get solved, he helped me as much as he could. Thanks!"
Vizio Model M470SV HDMI port nor working (won't recognize dvd player,Xbox,play station etc)
This unit has four HDMI ports. Input is not automatically set to the port that your devices are connected to. Take a look at the markings that correspond to the port that your peripherals are connected to, then use the Remote Control to change the respective HDMI port.
With your external device connected and turned on, press the HDMI button on the Remote Control several times in succession until the proper HDMI port is displayed. Output from your device should now be displayed on the screen.
Nov 27, 2014 | Vizio Televison & Video
Hook up xbox 360 tv
What kind of receiver? Do you have anything else like DVD player going thru receiver? My receiver has 3 hdmi in and 1 out (to tv) so all those equipment would just go to "hdmi" on tv.
Another way to do it is put your tv on exterior audio... for all sound to go thru your receiver.
Jan 05, 2014 | Televison & Video
Fine red lines on screen
Redlines usually mark for a failing part.
You don't mention if this lcd is used from external source or just as a plain tv. I would suggest trying different input port if hdmi is used.
Possibilities: faulty external cable, faulty input port, faulty internal cable, faulty internal board or connection, faulty screen
Oct 24, 2013 | Toshiba 46G310U LCD TV
Panasonic LG plasma no audio on hdmi 1
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Dec 29, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
WestingHouse HDMI port wont work with PC but will for xbox 360?
You should never try to connect any cables when the devices are on. Always try to connect inputs or outputs after switching the devices off manually. Looks like the input port has gone bad. Try switching off the monitor, removing the plug and leaving it for 48 hours and retry. If you notice problems still, it is better to refer it to a qualified service technician.
Jul 19, 2012 | Westinghouse SK-19H210S Television
I am not getting a signal on my tv when I connect to the receiver using an HDMI cable. What do I do?
First eliminate sources. For example, test another source like a dvd player / xbox,playstation gaming system, etc. If your tv recognizes these sources then it is a problem with your reciever and not the tv. If the tv does not recognize the other devices you tested then the hdmi port on your tv is bad.
Jul 29, 2010 | Vizio VO47L 47 in. LCD TV
Im trying to connect my playstation 3 up via hdmi, when setting up it says it detects the hdmi cord do you want to use it and i say yes then the screen goes black for 30 seconds, i have tried switching the...
Have you tried using another HDMI device with any success on the same port? It would be good trying something else on your TV just to make sure the TV isn't the problem.
Also, try turning your PS3 off, then, while it is off, hold the power button down for about 5 seconds. The system will beep, and it will reset the video settings. Try your HDMI setting one more time, but this time set it to 720 p to make sure the resolution isn't too high for your television.
If none of this works, you could possibly have a faulty HDMI port on your PS3. I've seen it happen before.
Feb 01, 2010 | Sony Playstation 3 (PS3) Console
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
Televison & Video Logo
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
