Question about TESORO Antico Wood Pecan Tile & Stone
What's the best cleaning machine or method
We love our new "wood" like tile floor, but find the "wood grains" are difficult to clean, a mop leaves behind a thin layer of mud. We are looking for a cleaning machine Please help! Thanks in advance
  • Maud Guckine
    Maud Guckine Apr 29, 2016
    Machine or methods are different from work to work. We can not use technology for cleaning carpet in floor cleaning. We will see what you want to clean?http://housecleaning.ie
    Problem Solver:
  • 5 Answers
Use a steam mop with a little vinager don't use anything soapy like Mr. clean that will only streak and cling the dirt to the grout
Posted on May 15, 2014
I have a chalk like residue/grit on my tile floor. I've mopped it several time and when I wipe my hand on the floor it feels rough and a white residue gets on my hand.
What you are feeling is the grout that is used to fill in between the tiles. There is always some residual grout. If it is a new floor then this is to expected and you can use a sponge to clean it. IF not the you are looking at re-routing it
Jan 09, 2015 | Washing Machines
Tip
How to Clean a Tile Floor and Grout when nothing else seems to work.
What you need is Cleaning Paste, a Scrub Brush, an Enviro Cloth and water. The picture shows a before and after. After years of mopping the floor with the traditional cleaning products, dirt had discolored both the tile and grout. I was down to needing to decide to start over by replacing the floor, or give it one last try. I had seen and heard about this product from a friend who I purchased the products from but I didn't really know if it was hype or truly something new that would work.
It restored my kitchen floor to like new! I never thought it would work but for the $50 it would cost in products if it worked, I wouldn't have to pay Thousands to put in a new floor.
I simply scrubbed on the cleaning paste using water and a scrub brush. Let if sit for a minute or two and wiped up the floor with my EnviroCloth. It took a little bit of time to do the whole kitchen but for me, it was definitely worth it!
I purchased these products from www.ChristineFrey.Norwex.biz
The Cleaning Paste has more then just floor cleaning possibilities.
on Jan 31, 2015 | Home
How to Clean Tile Grout?
First mop the floors to get loose dirt up, use a stiff cleaning brush ( they make small versions of toilet bowl brushes. Toothbrushes are to flimsy.) I usually use tylex to clean grout it does have bleach in it. TO keep it clean after all that hard work put down a coat of grout sealant.
Jul 06, 2012 | Home
Why isn't my x5 H2O mop not warming up?
If the mop is within warranty, return it as defective.
Dec 17, 2017 | H20 x 5 Mop
I would like the operating manual for home tek steam cleaner
HI...........................
Couldn't see a manual on their web page, but you can try emailing them http://www.hometekinternational.co.uk/contact.htm
Home-tek Steam Mop Instructions
The Home-tek steam mop is designed for use on tile, vinyl and wood laminate flooring. This type of mop works a bit differently than your regular cleaning mop, as it uses steam to safely sanitize your hard flooring surfaces while removing stuck-on buildup.
Difficulty:Easy Instructions Things You'll Need
  • Water
  • Micro-fiber pad
    • 1 Open the cap of the water reservoir. This is located at the base of the unit, at the top of the reservoir, and twist it off.
    • 2 Pour tap water into the unit until you meet the fill line; water temperature makes no difference.
    • 3 Make sure a micro-fiber pad is attached to the bottom of the unit. This will be included with your purchase, and you may need to replace the pads over time if they wear or become heavily soiled. Replacements can be purchased from the manufacturer. If you need to attach the pad to the steam-cleaning unit, position the shape of the pad so it matches the base of the unit and snap into place on all four corners.
    • 4 Turn on the power switch with your foot. The switch is located at the bottom back side of the unit.
    • 5 Push the steam mop over the hard floor surface, pushing the steam trigger as needed at the top of the handle. Continue until your floor is cleaned to your liking.
GOOD LUCK!!!!!!!!!!!!!!
Sep 23, 2011 | Kitchen Appliances - Others
Why are my wood floors not shining?
Well first off, I would not recommend using any time of steam mop on unsealed or natural wood floors. They will damage them because of the heat and moisture. If your wood is sealed then it would be okay for short amounts of time. meaning not keeping it in one position on a section of your floor for a long period of time.
Steam mops are not meant to Shine floors. They are meant to sanitize and disinfect. yes they do clean as well but if your floor is shiny after use then there is to much water coming out and not enough steam.
Sep 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Shark Steam mop and loved it for my kitchen vinyl floor. We just moved into a new home with hardwoods everywhere and I was wonder how well it worked on wood and laminated wood floors.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
It works great on hardwoods and laminate floors...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Feb 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I'm considering a steam mop. Do you know if they
I dont know if you are in the U.S or U.K If you are in the U.K there is a model called the Hometek Light n Easy. Its suitable for hard floor cleaning but poor on carpets. Generally most steam cleaners with carpet attachments dont do very much unless you consider premium machines such as Polti
Mar 13, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
TESORO Antico Wood Pecan Tile & Stone Logo
442 people viewed this question
Top TESORO Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a TESORO Building Material Expert? Answer questions, earn points and help others
