Question about Garmin GPS III
Garmin GPS III Pilot Display
I think my GPS III Pilot was transported (by me) within my breafcase where something has made a pressure to the display. Now the display has a figure in an egg form changing the intensity of the point of it. This way I don't see everything that is displayed. I sure have to replace the display. Someone can give me a way to do it?
  • 6 Answers
SOURCE: GPS displays BNG on location
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Posted on Jun 24, 2008
SOURCE: Garmin GPS 152
I had the same problem so I replaced my 152 with a spare unit. It did the same thing. This led to believe it was the cable. I removed a few kinks and a bend at the unit; and it seems to be fine. Seems too simple and the bends were not that severe, but it is working (for now).
Posted on Oct 07, 2008
SOURCE: need to replace memor4y battery
I have the same problem. how can I get it fixed?
Posted on Oct 11, 2008
SOURCE: display on my Garmin E-Trex Legend GPS
You can fix it yourself but be careful - thats how I comletly broke my eTrex http://etrex-gps.blogspot.com/ :(
Posted on Jan 24, 2009
SOURCE: Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Posted on Jan 28, 2009
While plugged into car garmin will not display maps
It has gone into "Mass Storage Mode" because it thinks it is connected to a computer. Are you using something other than the Garmin power cord such as a cell phone charger?
Apr 04, 2010 | Garmin nuvi 200W GPS Receiver
GPS III Pilot? will not power up
Try the dc plug too (also make sure the battery connections are good in the caste). IF still no power up, the internal battery may be shorted. Lots of info online for replacing the internal battery. Good Luck!
Sep 13, 2009 | Garmin GPS III
Gps screen has a black eye
The LCD display needs to be replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Aug 05, 2009 | Garmin NUVI 360 GPS Receiver
Street pilot 7200 keep shutting down after a download
your on board battery my be bad contact there website for more information and tech phone # fo help
Jul 27, 2009 | Garmin StreetPilot 7200 GPS Receiver
HOW TO CALIBRATE GARMIN STREET PILOT 2620
I am assuming you want to calibrate the touch screen. Press MENU, click DISPLAY, Press find, press find, follow instructions on screen. You can also hold MENU and FIND at startup and a diagnostic screen will start up, pressing menu repeatedly while on this screen will give you an opportunity to calibrate the screen. If you are looking for a solution on how to do something else, please post additional information and I will do my best to assist.
Jun 06, 2009 | Garmin StreetPilot 2620 GPS Receiver
Bad white lines on the Garmin gps III Plus display..... how we can repair it?
It sounds like you have a problem with the screen itself. Garmin at http://www.garmin.com has an excellent repair program. They repair your out of warrant GPS for a flat fixed rate. The GPS is like new when you get it back. Just to to the Garmn web site click on the support tab and follow the menu selections from there.
Apr 05, 2009 | Garmin GPS III Plus GPS Receiver
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS III Pilot to PC communication problem
If it were doing this just on the Vista machine I would say it was Vista related but since you are getting it from an xp machine as well the problem is either cable or the gps unit. You don;t say if this just started happening or ? If you can try out the cable on something else to make sure so you can eliminate it. About the only thing you can do is to make sure the port settings in the pilot are set correctly. Generally the slower the better if you are having communication problems as this makes the signal timing not as critical. Try 9600 baud to start. Make sure that the data bits are also set roght. This is the 8n1 or 7n1 thing you see. I can;t think of what the default is on the garmin but as long as both pc and garmin have speed, bits, parity, and stop but set the same they should talk.
Try to download from the unit as well as upload.Unfortunetly you can only change the speed and protocal or reset the unit. You won't be able to fix it if is a hardware thing. If you are using a USB to Serial adapter then I would say that is your problem or could be. Cheaper ones just don't work often on higher port speeds. You might want to try the gps on a pc with a actual serial port if you are using one. If it works then you should try a different brand of adapter or really slow down the speeds.
This won;t solve it unless you luck out but it should let you know where the problem is.
Dave
Jul 10, 2008 | Garmin GPS III
Garmin GPS III LCD screen problem
I have a GPSII+ that has a screen problem. Several of the x and y coordinates have failed and I think it is due to condensation in the unit due to hot day temps then cold nights. If I open it and dry out the unit for a while... the display will be better but will not return to full display. Some of the X and Y lines don't work.
May 12, 2008 | Garmin GPS III
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
Garmin GPS III Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
