Question about Candy Washing Machines
I cant open black flap behind white flap the white one screws of but the black one wont so i cant check for dirt
    President:
  • Candy Master
  • 662 Answers
Http://service.candy-domestic.co.uk/fault-finder/FaultFinder.aspx?Section=11
Posted on Apr 24, 2013
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
Taillights wont turn on
According to my manual for a 1997 model the park light relay is behind the dash at low level and towards the centre. its in a black box along with 5 other relays, the relay you are after has a group of wires with the following colours; tan/white, white/black, white/pink, brown. the brown wire is the one that feeds the lamps via 3 connectors and a splice joint. On my 98 model I can see the box by getting down into footwell and looking up behind the trim panel below the steering wheel, how the hell you get to it though is another matter. hope this helps and good luck.
Sep 20, 2012 | 1998 Ford Explorer
My fuel flap wont open anymore
try see if flat head screw driver open flap door, wrap layer tape on flat head screw driver to keep damaging car paint.just pry little see if flap will open.
Sep 04, 2012 | 2002 Volkswagen Passat
How to replace fuser unit
Hello,go to back side of printer & open the flap u will found two serews open them push the tray & open the two locks at right & left bottom then back pannel will come out.pullout the white strip where the power connector inserted you will find fuser connector (black,white wires)open 4 screws on which fuser wire attached detach two connectors situated right side wall of printer& you will find a teeth lock on the bottom side of fuser press the two leavers & pull outwardly & also pull out the unit outwardly & do as viseversa for fixing the unit.
Oct 08, 2010 | HP LaserJet P3005n Printer
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
My self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replace brake light on my 2002 Honda Oddesey passenger side
Open the rear hatch and remove the two taillight mounting screws. These screws are located behind two plastic flaps that are flush fitting and part of the tail light housing. You will need a small flat blade screwdriver to put under the edge of the flap nearest the light. Pry gently (but persistently) and the flap will open to reveal the screw head underneath. (The hinge of the flap is on the side nearest the hatch opening.) Remove the screws with a phillips head screwdriver or an 8mm socket. Now comes the tricky part. Wiggle/pry the taillight housing as straight back as you can. Keep pulling/wiggling until the forward clip releases. Once it does you will be able to access the bulbs by rotating the bulb holders counterclockwise. Pull the bulb straight up out of its socket. Replace with the new bulb. Note how the forward spear point clip fits into its socket at the forward outboard edge of the housing. Fit the clip and push forward on the housing until you can hear the clip snap into place. Replace the screws and fold back the flaps. You're done.
-T
Jan 15, 2009 | 2002 Honda Odyssey
Refridgerator ice maker not making ice
actually it should be blinking when door opened, try closint the little flap on left side of freezer liner, does hte light then become solid??? if so the electronic control is working correctly.. open the flap acessing to ice maker itself is there any ice in the machine now?? perhaps an ice cubes is jammed and not allowing hte icemaker to advance.. ck the little black nozzle(fill tube) crush it with your fingers is it full of ice???if so your fill tube is frozen and needs to be thawed. this is a pretty hard ice maker to trouble shoot. lastly theres ascrew under the rt corner if ice machine 1/4 nut driver. remove htat screw it releases acover for wires. the ice maker will pull out (youl need to push up a little tab along the left siderail inwhich the ice aker sits , after removed pry off the white cover if ice maker and look at the center gear. sometomes the tabs holding that gear on are broken in which case hte ice maker wont work and needs replacing(you cant sevice the main gear replace the entie assy. let me know what you find( iknow it sounds like a lot but youll be alright!!!!!
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Navman Pin570 battery replacement
There are 2 little black tabs at the botton of the back that you have to remove, behind these there are 2 screws u remove, and flip the ariel up and there are 2 screws under there you remove also.
The body is clicked together use a guitar pick, ur fingernails or small scewdriver to seperate the 2 sections.
Inside you will see a few screws holding the systemboard down, if need unscrew them.
you will see the battery its stuck onto the system board... be carefull seperating it,.. use a flat intrument or a butter knife to work it of the board ( its stuck on with double-sided tape or some kind of silicon)..
unplug it,
plug your new battery in.. BONGO
Let me know how you go.
cheers
plato
Put it all back together again
Jan 22, 2008 | Navman PiN 570 GPS Receiver
Washing Machines Logo
22 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
