Question about Hotpoint Refrigerators
Hotpoint ref
Is this a serial no? Model No? 197D8122P002
Where do I direct the hot air from an hair dryer to thaw out the water line in my hotpoint side by side refrigerator ?
Hotpoint ref.
made by GE
There is 2 different place they freeze up inside door water line for cold water dispenser & water feed to ice maker.
for cold water disp. Water line depends on model # will start at bottom of door loop over the disp. control and back down from top of control to cup area to defrost this line best way is to shut down ref and leave door on freezer open can take up to 12 hours.
taking door apart is a major project.
If its your ice maker fill tube easy fix turn water supply off.
on back of ref. there is a water line going up to the top of freezer
this tube will pull out from back the whole fill tube will come out
take to sink thaw with warm water replace tube You may need some caulk to seal area tube meet ref.
Mar 24, 2015 | Hotpoint Refrigerators
Why does water drip inside the ref toward tne rear of the ref? Happens once a day
That's the automatic defrost cycling. The water collects at the bottom and drains into a flat pan underneath for eventual evaporation.
Jul 19, 2014 | Hotpoint Refrigerators
I have a PANASONIC NSDN-W59 MODEL : 08545-00S61 REF : CQ-US0901CJ SERIAL: 76043 in my car and i change my battery now its need a code to unlock it. now what do i do?
Apr 04, 2013 | Panasonic Car Audio & Video
Need to know the year of a Hotpoint fridge. Ref numbers are: CTHY16EPERWH MF 780907
According to that model and serial number is was made in July 1991
Aug 24, 2011 | Hotpoint Refrigerators
The compressor does not switch on there are electrisity if i test is can it be the black unit that fit on the compressor it is an hot point hd 250 ab serial no dehfoi 058 237l
Thats call the compressor relay most likley thats gonna be your problem unless you have a control board on the back of the ref.
Aug 22, 2010 | Hotpoint Refrigerators
Hotpoint dryer model DLB1550BDLAD. How old is
get the serial number and go to www.hotpoint com.and yes they are still a company.adrian,,,,
Jul 12, 2010 | Hotpoint Dryers
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Jun 26, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
Refrigerators Logo
50 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
