Question about Denon Dn-s3700 Dns3700 Dns S 3700 Cd Player Turntable
Denon dn s3700
I keep getting a disc error message CD won't load
robotek
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
SOURCE: TOC ERROR ON DENON DN-C615
Take this info with a grain of salt. I recently received one of these units with a TOC error, and after removing the drive assembly and reinstalling it, the problem went away. Before removal, I observed the motor spinning poorly and even backwards. Rather than pull the whole drive assembly, I would first eject the drive and remove the face from the tray. This is done by putting your thumbs on the tray and pulling up with your pointer fingers underneath the face. It should just snap off and snap back on the same way. Try playing a disc now, if it works try loosening the screws on the drive assembly and shifting the assembly towards the front of the unit, tighten the screws and put the face back on. You should be good to go. There are four screws holding the assembly down, the two in the back can only be accessed when the tray is in the open position. The front two are accessible through holes in the tray, and I don't recall if the tray has to be open or not, but that's easily observable. If it's still not working, there is a flat-flex cable running to the laser assembly. Pull and reseat this gently. Try to only manipulate the cable by the blue reinforcement tab. I hope this helps!
Posted on Nov 30, 2008
SOURCE: need an instruction manual for denon dn-1800f?
http://www.denondj.com/Assets/Dimages/Products/Manuals/cd709d3d980d4f2d8013fea6e875c68d.pdf?ts=062556
Posted on Feb 20, 2009
  • 17 Answers
SOURCE: help with denon dn-s3000
CD lens cleaners are not to be used with these slot load cd players (as per the manual).
Please visit www.denoindjforums for further help.
Posted on Mar 10, 2009
bhatgiri73
  • 106 Answers
SOURCE: Hi. My denon dn s3500 just says disc error when I
clean the lens...if it does not work replace the lens.
Posted on Jan 24, 2010
Denon dn s3700
Usually this is caused by the laser getting lazy or dirty. You could try taking the lid off and carefully cleaning the laser, (You could get lucky), but this is usually just a token gesture. I have had success with boosting the voltage to the laser but this in turn produces alignment problems and then must be recalibrated and is still only a temporary solution. If you are attached to the unit have it repaired. It is a nice piece of equipment. Otherwise look out on Ebay for a moderately priced replacement. Cheers Bob
Aug 12, 2014 | Audio Players & Recorders
The platter for the denon 3700 keeps stoping
http://usa.denon.com/us/support/pages/Service-Network.aspx . Since it's a direct drive platter the motor or control circuits are giving you a fit. Check out the URL above for all the information you never wanted to know.
Jul 16, 2014 | Denon Dn-s3700 Dns3700 Dns S 3700 Cd...
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
CDJ NOT READING CDS. STATES (DISC ERROR)
If it shows No Disc error to all CDs, either its Sled Motor [The motor which spins the disc inside], or its optical picku unit has the fault. You have to contact the nearest Denon authorised service center to get it repaired, as Denon uses special type machanism with theirs sets, and it can't be available at open electonic spare part market.
Apr 23, 2012 | Denon DN-S700
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
Denon DN-V210 won't play DVD's burnt with Final Cut Pro
Then the format can't be read by the MAC, what reason this is I have no idea.
Apr 11, 2017 | Denon DN-V210 Player
Help with denon dn-s3000
if the cleaning cd don't work then it will need to be cleaned by hand , and if that don't do it then you will need the laser mechanism replaced
electech
Oct 29, 2008 | Denon Dns1000 Table Top CD Player CD...
Denon Dn-s3700 Dns3700 Dns S 3700 Cd Player Turntable Logo
54 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
