Question about Sony Cybershot DSC-H3 Digital Camera
How to tighten the loose mode button?
The mode button is loose and slips out of the mode setting .
    Sergeant:
  • 321 Answers
Due to hard press. replace the button magnet
Posted on Apr 26, 2013
I purchesed a BS18G Cordless Drill. How & when can I use the indication dial from 1 to 24 thank you
This dial is a torque setting. The higher the number, the higher the torque. Torque is a measure of how hard something is turned. For example, suppose you were using a regular screwdriver to tighten a screw. If you were to hold the screw driver loosely in your hand, your hand would slip before you tightened the screw very much. If you squeeze the screwdriver handle tightly, you could tighten the screw a lot more. The low numbers are like holding a screw driver loosely. The mechanism will slip before it tightens very much. This is only useful when you are trying not to overtighten small screws. When you are using it to drilll holes, you will want to set it at the maximum. Good luck, Al K
Apr 26, 2011 | Garden
Belt slips while walking
Sounds like the belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Apr 17, 2010 | Cadence Exercise & Fitness
Belt is slipping
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Apr 03, 2010 | Cadence Exercise & Fitness
Belt is slipping
Mar 29, 2010 | RTO Image 15.0R Treadmill Walking Belt
Belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Mar 06, 2010 | Exercise & Fitness
Belt is slipping on healthrider treadmill
Apr 30, 2009 | Icon Exercise & Fitness
Belt & motor stops
Apr 14, 2009 | Exercise & Fitness
Belt is slipping and catching
Apr 09, 2009 | Exercise & Fitness
Slipping mat
Mar 26, 2009 | Exercise & Fitness
Belt slipping on treadmill
Jan 06, 2009 | Exercise & Fitness
Sony Cybershot DSC-H3 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
