SOURCE: frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
