Printer fault canonip4000 5orange flashes then 1green does not print.just replaced all cartriges!any simple fix?
  • 27,725 Answers
The Canon Pixma IP 4000 printer has a self-diagnosing print head error notification system. Generally the "Alarm/Power" light will flash and tell you what kind of problem you might be having with your print head.
You can also run tests yourself to identify problems.
Look at the "Alarm/Power" light and see how many times it's flashing.
If it flashes orange 11 times consecutively, that means there is a print head alignment issue. Perform deep cleaning, then move the printer away from any strong light sources.
To deep clean, click the Maintenance tab in the "Printers" folder.
Then click the "Deep Cleaning" icon. You can select all colors, black, or selected colors. Click on "Execute."
If it flashes orange five times consecutively, that means there is a print head error.
Reseat the print head, then reset the printer.
To reseat the print head, make sure the printer is on.
Open the paper output tray and top cover.
Make sure the print head holder is in the center and open the inner cover. remove all the ink tanks.
Raise the print head lock lever and remove the print head.
Reseat the print head and lock the lever.
Replace the ink tanks.
Check to see if the ink is ejecting normally from the print head nozzles by running a test.
Press and hold the "Resume/cancel" button.
When the Power lamp flashes twice, release the button.
Examine the printed output.
Use the references below to compare your output to what Canon suggest is correct.
If the output is incorrect, then perform deep cleaning, if necessary repeat twice.
Replace the ink tanks if you're unable to get a good result by following the previous steps. make sure the printer is on, lift the top cover.
The print head holder will move to the center.
Press on the tab to release the tank.
Unwrap a new tank.
Make sure you can see the air hole and insert the new tank until you hear a firm click.
Repeat for the other tanks if you suspect from your print test that they have failed.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10239 - SupportDetailAct
Posted on Apr 24, 2013
HOW DO I FIX THE INK CARTRIGES WHEN REPLACED ?
Could be improper installation, or cheap cartriges, or could be failed print head which I had and replaced with good results.
May 21, 2014 | HP Photosmart C6380 All-In-One InkJet...
Tip
Cleaning Print heads when all else fails
The nice thing about this printer is that it can use the cheap aftermarket ink. The problem is, this ink can sometimes cause the print heads to not clean properly. The tip that works to fix a baldly clogged print head is to remove the print head, and spray and soak it in "Simple Green" for at least 3 hours. Then use compressed air to force the "Simple Green" through the heads from the screens in the ink wells, to the print head. Then use the air from the print heads, you will see foaming by each print screen. Be carefull not to lose the small rubber inserts around the print screen. Rince the print head with clear water and repeat the compressed air until dry. Replace, and put the ink cartriges back in, and bingo, your printer will work like new again!
on Dec 22, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
Aug 13, 2009 | Canon PIXMA iP1600 Printer
Printer wont print black text
After a deep clean, and re-seating
It's a lemon, it's faulty,
Replace it.
Regards.
Apr 15, 2009 | Office Equipment & Supplies
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
Problem with cartriges
EC5 = Print Head Short. Short test detected short circuit in printhead. Fix is to replace print cartridge(s).
Sounds like one or both of your new cartridges are defective and need to be returned to where you purchased them.
Mar 02, 2009 | Lexmark X2600 InkJet Printer
Printer problem
It sounds like a bad encoder strip (ribbon cable). Uneconomical to repair.
Sep 25, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Color
Sep 10, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Printing RAINBOW of colors!
Change the color cartridge and see what happens.
Aug 06, 2008 | HP Deskjet 6940 InkJet Printer
471 people viewed this question
k24674
