Question about Kwikset Professional Door Lock installation Kit
Tighten the outside faceplate of a qwikset dead bolt.
I have a qwikset deadbolt. The outside faceplate is very loose. I want to tighten it. There are no visible screws on the inside faceplate. I have a T knob on the inside which I can remove with a # 1/16 allen wrench. I can't figure out how to remove the inside faceplate or tighten the out side face plate.
  • Anonymous May 02, 2009
    I've got the same problem. After removing the thumbturn, there's no screws.
  • 10 Answers
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Posted on May 22, 2009
Remove deadbolt
Look for screws on the edge of the door. They might be hidden under a cover plate. There is always a way to remove a lock.
Aug 17, 2014 | Locks & Locksmithing
How do I tighten a deadbolt lock with no visible screw? It has key on both sides. Inside plate has 2 holes in it that I thought would rotate to expose screws. It does not. How do I proceed?
On the inside of the door, the lock has a trim ring around it. Look for a slot on the ring, place a flat screw driver into the slot and twist the screw driver to remove the trim ring.
Jul 19, 2014 | Kwikset Locks & Locksmithing
How to tighten up a loose face plate of a Kwikset Deadbolt door lock. This specific deadbolt lock doesn't have screws on either side. The face plate is so loose that I can spin it clockwise but it never...
The exterior faceplate is not the thing that fastens to the door, it just supports the lock cylinder and covers the hole in the wood. Inside the door the cylinder has a thin plate with two screws going from the inner door surface into the back of the part you put the key into. Removing the big nightlatch block you will see a metal tang on the inside sticking out. The two screws will be just to the left and right of the tang and so you can draw the lock cylinder inward from there, which will squeeze the outside faceplate bezel into the front door surface. These are great locks, I am installing one from the 1940's which even opens up to let you reverse the bolt angle and make the door open outwards if you want to for big industrial shop doors.
Mar 28, 2011 | Garden
Deadbolt lock is loose and needs tightened. How do I open to get to screws?
The main attachment point is the door edge--usually two larger screws. If you want to take the whole mechanism from the door, you need to remove the inside latch button from the door face. That should also release the outside lock part. Hope this helps!
Aug 13, 2010 | Garden
Deadbolt loose,lock has no screws showing on the outside.how do i tighten deadbolt?
Usually the screws are on the inside by the thumb turn. If there aren't any screws there either... then you need to turn the lock case clockwise to tighten.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 04, 2009 | Locks & Locksmithing
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
How do you remove knob on schlage deadbolt so that you may remove faceplate to tighten screws ?
turn knob as usual, there should be a hole in the bottom after you turn it. push a small screwdriver and it will pop right off.
Apr 04, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Kwikset Professional Door Lock installation Kit Logo
4,327 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
