Hp pavilion p6000 series user manual - Computers & Internet
  • 302 Answers
SOURCE: need user guide and instruction manuel for hp pavilion
goto this web site and type in the box your product model and it will give you options for manuals software and driver downloads etc.
the manuals are PDF format which requires adobe reader be installed.
click on this link.
enter product number in the box that says enter product number.
http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us
Posted on Jun 22, 2010
joecoolvette
  • 5660 Answers
SOURCE: My monitor lost signal and
"My monitor lost signal and mouse and keyboard lost signal as well."
That would be because the computer isn't working.
No Signal on the monitor means it isn't receiving a video signal.
At first diagnoses one would check the monitor cable to see if it is good. Due to your added statement that the mouse, and keyboard have no signal, it definitely means the computer isn't working.
(The monitor cable would be removed, and installed on a known to be working computer, and monitor to test it)
You may see LED lights light, and perhaps fans spin, but the Processor isn't turning on.
Not enough power, or the computer is dirty inside.
(Or a combination of both; Read on)
The hardware components inside the computer are cooled by air.
{ Hardware component examples such as the Processor, Ram Memory, motherboard, graphics card, (IF installed), etc.}
This support page on HP Support, shows how to open the computer case ,of an HP pavilion p6653w desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684297&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=4313690
I would like you to have this information of how to open your computer case, but would also like you to view the 6th photo down, showing the side panel of the computer case removed.
Not a very large photo of the inside of your computer, but helps me explain.
At the bottom is a black plastic Fan assembly.
This is the Processor fan.
The fan sits on a finned Heatsink, and the Heatsink sits on the top of the Processor's case.
The Fan and Heatsink are the cooling components for your desktop computer.
They need to be clean, as well as the entire inside of the computer, but more attention needs to be paid to these two components.
When a Processor overheats it turns off. (BIOS turns it off)
This is a fail safe feature designed to keep the Processor from burning up.
(A Processor has a Thermal Limit)
No Processor operating, No computer.
This Fan/Heatsink combo is similar to the design in your computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7151732&CatId=4922
Note the fan blades, and square surrounding cage. (Shroud)
The fan blades, center hub, and surrounding cage must be kept clean.
Note the aluminum looking finned square object under the fan assembly.
This is the Heatsink.
(Left-click on the photo, then in the small window that comes up, hover your mouse cursor over the different views)
The Heatsink is essentially a flat plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, (In this case a Processor), and the tall, thin fins absorb heat from the plate of metal.
The fins then radiate the heat away. The fan pushes air in-between the fins, and around the fins, and helps to carry heat away.
In-between the fins, and on the outside of the fins, needs to be clean.
A) Computer unplugged from power. Open the computer case on a table.
It is now time to observe Anti-Static Precautions BEFORE reaching inside your computer.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer case open, computer unplugged from power, TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
If you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
Buy two cans of compressed air for computers. Break the lock tab off of the top of one can, insert the plastic straw provided.
Refrain from tilting the can of air. It will happen, but try to refrain from letting it.
(The propellant comes out, and the can freezes up faster)
I would suggest starting with a few Q-tips on the fans blades, center hub, and shroud.
You aren't trying to wipe the 'Gunk' off, just disturb the 'crust'.
Once the outer 'crust' is disturbed, the air will remove it easier.
{You may wish to wear a dust mask}
Use the straw, and point it at the Heatsink fins. Move in a pattern as you clean.
Suggest now to start at the top left inside corner of the computer case, and spray air to the right top corner. (Inside)
When you start hold the can level, and squeeze the trigger in all the way. As you reach the end of the other side, let go of the trigger.
Move down a couple of inches, spray across again. Keep going until you reach the bottom of the computer case. Spray as a professional paint sprayer would.
Tilt the case top forward towards you, and spray the bottom out.
Close the computer case, plug the computer back into power.
WAIT 2 minutes, turn the computer on.
{As you spray air you will notice along the way that the air pressure drops. The nozzle opening of the can of air is freezing shut. Sit the can down, let it warm up. Use the second can of air }
If this doesn't solve the problem, the problem is a bad Power Supply.
Enough power to turn on LED lights, and maybe spin fans, but not enough to turn the Processor on.
1) If all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
(Older processors such as a Pentium III for example, use less than 51 Watts)
The AMD Athlon II X2 250 processor in your computer can use up to 65 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_X2_microprocessors#.22Regor.22_.2845_nm.29
You can replace the Power Supply yourself, and save money.
I can guide you on here, and give you links to detailed information.
I can also recommend a Power Supply with the thought in mind, of the 'Best bang for the Buck'
Reliable, and yet economical.
(One such example of how to replace a Power Supply, in an HP Pavilion p6653w,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01684432&tmp_task=useCategory&cc=us&dlc=en&lang=en&lc=en&product=4313690
For additional questions please post in a Comment.
(Believe upper right of your page. Our site is revamping all the time)
Regards,
joecoolvette
Posted on Jul 18, 2011
  • 669 Answers
SOURCE: I need the user manual for an HP p6000 series 2011 home computer
Here is a link directly to HP for your computer. There is a link for product user guides here, and other information.
http://h10025.www1.hp.com/ewfrf/wc/product?product=4320258&cc=us&dlc=en&lc=en&jumpid=reg_r1002_usen
I hope this helps
Posted on Dec 16, 2011
SOURCE: Hello I have a hp pavilion p6000 series,and
If the monitor is not booting up than may be there is display problem on the mother board. Replace the CMOS battery of the motherboard and then check. If this solution not work then there is technical problem in the motherboard which will get fixed only by expert motherboard repair technician.
Posted on Jan 06, 2012
maxcarson
  • 7627 Answers
SOURCE: user manual for HP pavilion dv6-7028tx notebook
You can start here:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c03292693
Posted on Nov 17, 2012
I just replaced hardrive in hp pavilion p6000 series, how do i get the software that came on tis ystem since there are no more hard copies
Contact HP. They have copies of it that you can buy. They should be available unless the version of windows is obsolete.
Jul 24, 2014 | HP Pavilion P6000 Desktop Quad-core...
New memory stick 4 gb doesn't work
you cant do that. memory is always in PAIRS. The sockets are Colour Coded for each PAIR. two blue two black. the largest may need to be 1st Pair. suggestion: take all 4 out. put 2 largest back in as 1st pair see if pc is ok. then add 2nd pair. see if ok. https://support.hp.com/gb-en/document/c02014355 https://support.hp.com/lamerica_nsc_carib-en/product/HP-Pavilion-p6000-Desktop-PC-series/4079858/model/4123110/document/c01989040 https://www.mrmemory.co.uk/memory-ram-upgrades/hp/pavilion-desktop/p6324uk?search=hp+p6324uk
Dec 20, 2017 | MSI Hp Iona-gl8e Oem Motherboard Ms-7613...
When i play games on my p.c. they have lines running through the picture
maybe thats a video card problem,try installing other vcard and see if you can still see particles.
or if you are using ATI try checking program controlled the anti aliasing
Aug 20, 2012 | HP Pavilion P6000 Series,amd Sempron...
Hp p6000 ethernet download for xp
http://download.cnet.com/hp-en1207d-tx-pci/3000-2112_4-137726.html
if this driver is not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name ethernet driver you might have to try a few times to get it right
hope this helps
Jul 04, 2012 | HP Pavilion P6000 Series,amd Sempron...
Need to download onwer,s manual for HP Pavilion ze 4400us
HP Support > Pavilion ze4400US Notebook PC > Main Support page.
[ The Pavilion ze4400US designation indicates the
Pavilion ze4400US - SERIES - of Notebook PC's;
Pavilion ze4401US
Pavilion ze4402US
Pavilion ze4420US
Pavilion ze4424US
Pavilion ze4430US
Look at the white Service Tag on the bottom. P/N stands for Product Number. The EXACT model number.
I chose ze4401US because it is one of the ze4400US series. A User Guide for it applies to all of the series ]
Click on Manuals.
Now click on -
HP Pavilion ze4x00, ze5x00, and specific xt notebook series - Startup Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
(Took 10, and am using medium speed DSL connection)
Anything specific I can help with, or did you just need the User Manual?
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2012 | HP Pavilion Computers & Internet
Hello I have a hp pavilion p6000 series,and everytimei try turning it on it won't boot up the monitor?
Jan 06, 2012 | HP Computers & Internet
I hope this helps
Dec 09, 2011 | HP Computers & Internet
Lost my Users Manual for Coolpix P6000. Unable to download.
http://support.nikontech.com/app/answers/detail/a_id/13948
http://www.nikonmall.com/category/instructionmanuals
Aug 03, 2009 | Nikon COOLPIX P6000 Digital Camera
How can I look at the user manual on the internet
On the manufacturers website, hp.com or at usermanuals.com
Jul 08, 2009 | HP PAVILION DV4000 SERIES USER GUIDE -...
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
