Question about Microwave Ovens
Jvm1750sm1ss mark on the screen F3
  • Microwave Ovens Master
  • 9,098 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11054 and you can get it from the Pros here.
You can also find helpful exploded view diagrams at that link.
Posted on May 03, 2013
JVM1750sm1ss micro-oven, totally dead when plugged in.
see the diagram and proceed with common sense use the VOM
God bless you
7_17_2012_2_10_43_pm.jpg7_17_2012_2_11_13_pm.gif7_17_2012_2_11_40_pm.jpg7_17_2012_2_12_03_pm.jpg
Jul 16, 2012 | Microwave Ovens
Microwave won't turn on
Depending on the make helps determine the problem, if there is no power it is more than likely the fuse is open.
Apr 09, 2012 | Microwave Ovens
I have a new (2009) microwave GE JVM1750SM1SS and suddenly turn off. I turn off and back on the microwave main breaker. I checked the outlet and it has energy. I plugged in back the microwave but it...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 30, 2010 | GE Microwave Ovens
After a power - cut the Micro can not be switch on. What can we do? Type: GE JVM1750SM1SS
A mains "spike" has probably broken the fuse. Replace the internal fuse if you are qualified and competant to do so, otherwise get a repair person in to repair it.
Oct 16, 2010 | GE JVM1750SMSS Microwave Oven
GE MICROWAVE OVEN, MODEL JVM1750SM1SS, WILL NOT HEAT. EVERYTHING ELSE WORKS.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 19, 2010 | GE Microwave Ovens
It shows f3 in the screen
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jun 01, 2009 | GE JVM1870 Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a new microwave oven Model JVM1750SM1SS. Does this model allow me to use seconds rather than minutes. For instance can I place a frozen dinner roll in the oven for twenty seconds?
It should. Normally to cook 20 seconds you would pres COOK TIME - 2 - 0 - START.
You can download your owner's manual free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | GE Microwave Ovens
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
